Just a thought but when you consider that the switching fet in this case the IRF9640 has an Rds of 0.5ohm that in order to ensure maximum power transfer the coil resitance should also approximate to this value also.
If your coil resistance is too low then you should add some series resitance to your coil or alternativley if the coil reistance is too high then you would need to look at how you can make a coil with lower resitance.
Remember also that the frequency of the pulse in your case is approximatley 12us on and 12us off or period of 24us or approximatley 42kHz.
When switching the current through a 300uH coil at 42kHz the AC impedance will be 6.7 ohms compare that to if you would use 30us on and 30us off, f = 17kHz and will have an AC impedance of 4.54 ohms.
Also depending on the parrallel capacitance of the coil the higher the switching frequency the more losses in the coil as the capacitance impedance decreases as the frequency increases.
So for example if the coil capacitance is say 100pF the parralel resitance at 42kHz would be 159 ohms while at 17kHz it would only be 6.3k ohm so a big difference.
In other words the losses at lower switching frequencies are much better than at higher frequencies.
If you wish to reduce the flyback voltage and maintain the original 17kHz frquency then it will probably be better to introduce some resistance in series with the coil to reduce the DC current.
