This topic is closed.
  • Originally posted by authere View Post
    Hi Moodz,
    Did you get the can at 6' !!!, an 18" coil @1us will open up a lot of ground that was too deep for the littlies, how will this result help with the larger deep nuggets
    Ron
    PS:Is there much else to do cause i'm finkin i gotta sell me M/L
    Not yet ... Still tuning the components but there is no sample hole .. So the detection range scales with the target size up to the coil limitations. Big nuggets should not be a problem ground balance is inherent in the technique and earth field cancellation is also now inherent and not dependant on a sampling technique. Don't sell the ML yet though.
      ... been fairly busy with other things however the earth field rejection tests have proven successful. I realised I forgot to check the waveforms around the front end after I did the earth field mod and ( unintended benefit !!! ) the mod actually improved the "no resistor" LOL damping method. I am now getting the minelab reference coil ( actually its a commercial nuggetfinder mono coil ) to damp in 3 microseconds ( was previously around 5 microseconds which was still good ) so I picked up a couple of microseconds.
      Now the pic below shows the waveform at the output of the first stage of the detector, the white trace is the mosfet gate, you can guess the rest, its not a very big target but its "tc" is definitely not near 3 microseconds and some of you will realise why my damping method is new and that the old math dont count no more. ... clue the only bit of the waveform that moves is the bit after the flyback ... and no dorothy ... I am not using a switch to do that .. only the target LOL
      ( maybe get ready to see alot of PI patents become old hat in 2013 ... )
      [ATTACH]22737[/ATTACH]
      I will take a guess. You are obviously using Bi_polar Tx utilising PWM (positive and negative to zero reference) and alternatively switching simultaneously between a N-Mos and P-mos for critical damping without a R load.
      Just a guess.
      Sid
        Hi Moodz,
        I have no rush to sell the M/L's as they paid for themselves 7 times over although it would be nice to get my hands on some new technology we certainly do have to be patient
        Ron
        • Moodz, I am really guilty of raising the QED, BW issues here and then it all follows. It is really a waste of time and energy --- but someone has to defend open source spirit. Really I feel very sad for BW enterprising spirit. But this thread is an alternative to what can be done in PI technology - slowly and steadily the thing were progressing - BW and his team may come up with maybe "donate-ware" where the people interested with the BW plans may donate him for the works he produced - sure this also goes for Moodz' project as well. Maybe someday the world will all see the projects in all major electronic magazines worldwide with kits free on contest. UF & PJ - to you - well nothing to say -- I have better things to do.
          • Originally posted by sido View Post
            Just a guess.
            Sid
            nice guess ... But the timing on that would have to probably be nanosecond accurate given the dv/dt around the vicinity of the flyback ... The r load issue is relatively simple from a conceptual viewpoint.....it's a problem that has been solved in all engineering fields ..except pulse induction metal detectors apparently. If you are a ham radio guy you will recognise the funny side of it straight away ...us hams ... Well most of us ... Don't use resistors to match the antenna to the receiver/transmitter... It's so funny from a technical view point that it has been got so wrong for all these years and the patents with elaborate sampling schemes and pulse timings trying to correct what was missed in the first place.
            moodz
            • Originally posted by vbeeeks View Post
              I agree with you vb ..everyone should concentrate on building a complete design and spend less time ranting ... The QED from all accounts is such a machine. I have seen it working and it really is impressive.... It's a complete machine not just some ideas on paper ... Seeing it work inspired me to stop getting caught up in discussions on coils and amps and get back to the bench to complete an end to end detection system. I actually do now have a complete end to end design now .. Is it perfect .. No ... But alot of major problems have been solved with an engineered approach .. No fancy components .. Just principles and application ... now I can work on making each subsystem incrementally better ...
              moodz
                moodz
                Thanks Moodz, it was just a guess, but see where your refering too.
                Am a bit of a Radio enthusiast and can only suggest a means of matching the TX load to a inductive matched network transformer for maximum power transfer and a ideal impedance match to the input first stage op-amp.
                Using a variable inductive auto-trasnsformer as a mis-match toroid of some form.
                Therefore no loss in return heat generated in a non resistive component and end result a ideal transmatch between TX and Coil to input stage at variable resistive loads that may be present.
                Sid
                • G'day folks,
                  I'm new around here, having arrived with what I thought was a great open-source design idea. And a knowledge of almost no relevant mathematics (well, maybe not none, but bugger-all, as I'm dysmathic). Then I started reading this utterly fascinating thread... THen my brain exploded.
                  So. Now that I (and anyone else reading this thread) have bandpass-filtered the (otherwise excellent) über-knowledge from the treasure (so to speak!), we now know that moodz' original detector design is no longer in an "available for experimentation" type situation. I'm reluctant to call it proprietary, although I guess it is... Hmm. Anyway, would anyone be able to help me/us understand if there is a point in the design that we/us could use ourselves as a starting point for implementation/inclusion in our own design(s)? Without causing "issues" for the current, obviously sensational, design?
                  If this has already been done and is available in another thread (which I'm about to embark on reading through in any case), please accept my humble apologies! If not, can someone perhaps point me/us in the right direction?
                  I'm going to be coming back to this thread over and over again in the next few months, because there is so much that I find utterly significant in so many ways, although the higher-order maths is almost impenetrable to me (and I thought I was a clever clogs because I finally understood general AND special relativity!). So thank you to everyone who added so much to this amazing read. I'm truly gobsmacked. Although I note it hasn't affected my digital diarrhoea. And so I must apologise for that, too!
                  THanks guys, for an excellent hours' read! You just made my darn day!
                  Cheers,
                  Suitably humbled Pete the Builder
                  • (Post#200).....The next steps are to build the samplers / demodulators and construct the code to do the (V1 - 0.77V2 + tan(V3)) * 0.006V4 ... .... or whatever the algorithm is going to be for target extraction. -Moodz
                    Moodz what is that unexposed algorithm ... for the target extraction ... Is it coded and working? Is it patented or will show up sometime in the future hex? ... curiously struck me while reading and rereading the posts umpteen times. What kind of output it will give - polyphonic audio or screen alert?
                    • Originally posted by Pete the Builder View Post
                      G'day folks,
                      Don't be so humble. You will probably find in reality that you have a superior practical understanding of this technology than many other members.
                      As far as the mathemetics goes, try reading Engineering Mathematics by K.A. Stroud. Many graduates owe a debt of gratitude to Ken Stroud, and his book has been described as "one of the most successful mathematics textbooks ever published". I have both first and second edition copies, and there is currently a 7th edition available on Amazon. Mr. Stroud also wrote one on Laplace Transforms, and another on Foundation Mathematics amongst others. It's like having a personal tutor, and you can proceed at your own rate. Highly recommended.
                        G'day folks,
                        Cheers,
                        Pete ... ... I dont know how you get the perception that this is not open .. since I have published the differential coil, the frontend, the backend, the sampling in the middle and the source code. The only bit I have not published is a radical new take on coil damping , ground balance, EMI and earthfield for PI detectors ... which actually is not really suitable for differential coils .. so that is not part of this project as this is a differential coil PI thread ... ok I might be guilty of hijacking my own thread ... but I dont think that is a crime.
                        However if you want to build a detector dont take too much notice of everything you read here on this forum ( entertaining as it may be ) ... to quote the bard ... there is much ado about nothing. If you want a good PI detector you will need a sensor ( ie coil ), a front end to first energise the coil then receive in a repetitive manner, amplification, some sort of sampling or demodulation, a method of generating one or more pulse sources and adjusting same, some sort of indicator system .. audio / visual or similiar and a battery or power system to provide the appropriate voltages. What you wont find so easily here is a ground balance method, an earth field cancellation technique and EMI rejection methods. Lots of discussion but few practical examples. However if you are a coding wiz the EF and GB should be relatively easy to figure out.. The EMI also is not rocket science. So that pretty much sums it up .... should only take you about 4 years or so to produce a cutting edge detector ....
                        • Thank you for the excellent suggestion. I'll dig a copy up. I've tried rebooting my maths via secondary school textbooks (analytic geometry, trig, calculus, etc), but my stumbling blocks were fractions. (I failed maths all through school, despite lots of resources). I even bought a set of Euclid's "Geometry" to see if going back to basics would help... it did, a little, but not enough attention went to the theorems and proofs, too much about what the Greek philosophy was... The last book I tried was Roger Penrose' "The Road to Reality", which is stunning, but I halted at page 31. Complex numbers? I've created Mandelbröt set renderers, but only by the skin of my teeth!f
                          Anyway, a sincere thanks for the suggestion!
                            ]Sigh. I've been dipping into various threads in this subforum, and I could've sworn I saw a comment saying the design was now unavailable. I will go through my history and verify. I'm delighted to hear it's alive and kicking. I'll dig through and collate the info, now that I know it's all there. Thanks!
                            I'm just smart enough to know just how "easy" it is to do all that you suggest - and how hard it is to get working! I started off with grand ideas of a simple (ha!) mode-switching detector based on a fairly cheap/powerful MCU, with a simple (ha! again) front end and amp, with straightforward sampling and curve fitting and... Once I worked my way through the history of PI, and saw many of the patents, and saw how many *real* engineers had spent so much time in this field, I realised that with my maths "skills", I needed to rely on other people's approaches to the problems. I guess that's one thing I'm actually really good at, being able to patch together various designs without breaking, faulting, or letting the smoke out. I love doing it, and I learn, too - win win!
                            I can code (I've been doing it for a living, on and off, for 30+ years, admittedly mostly DOS and windows (and now macintosh) high-end stuff, but I've kept my head above water technically with the micros (I still have working Z80 systems, which is sad, I guess!), but again, my poor maths grasp lets me down. Show me a matrix and a dot or cross product term and I start sweating and losing hair... Hell, I've been working on a Kalman filter for about 3 weeks for another project, and I had to stop and go to iTunes university for a refresher course on matrix maths - then I discovered I needed linear algebra, so that was another course, then I realised my fractions were terrible, so I've gone back to primary school courses to try and pick it up again. Did I mention I turn 50 this year? My brain is full of things I don't need...
                            Anyway, thanks very much for taking the time to respond so fully. I've learned more from this forum in a day than I've gleaned in a week on my own. So kudos, dude!
                              Yes its coded and working ... the original algorithms were based on traditional sampling techniques ... the new algorithm is not, since damping, GB, EF, EMI and target detection for the "new" PI are a function of a single composite algorithm. The output is no different to a sampling PI in response though probably better SNR by at least two orders. There is a certain satisfaction in knowing something that no-one else knows ( at least to my knowledge and research). Polyphonic audio and visual alerts could be provided but not necessary ... unless the company has a marketing department LOL. The last problem to be solved was the earth field rejection which now gives me a fully competent design to tweak. The dynamics of the system allow the PI to run as high as 20 Khz with a standard minelab mono coil ( have not tested higher ) with amazing sensitivity results because the coil can be damped so quickly the TX rate can be increased and I dont have to wait to take samples for GB and EF
                              • The maths for PIs including target reponses is hellish .... better to forget it ... I suspect it is incomplete. Clue ... if you want a top machine ...there is a schematic on the web ... search on QED .. there is some info here at Geotech but more elsewhere ( cant say exactly as there is kind of a civil war involved about it as well ... and I dont mean Intellectual Property related ... ). This design is as good as or better a performer as machines costing $7400 more .
