This topic is closed.
  • Nice Try.
    No, it's a prior art.
    I'm just curious, whether the patent examiner is dumb or unskilled. Let's see, what he is going to do with the patent application.
    • The interrupted TEM or the interrupted LC resonant circuit:
      http://www.geotech1.com/forums/showp...&postcount=840
      The slight residual coil energy (due to imperfect zero-current-switch and parasitic capacitance) is damped with damping resistor in the above application. If you remove the damping resistor in the application above, you get the same behaviour.
      The coil energy in the capacitor can be recycled back or burnt into heat in a resistor.
      The big quiz:
      So where comes the "huge target" response???
      Where comes the timing change (for discrim)???
        No its not prior art ...you have not seen the claims in the patent ...the inventor of the car does not claim an improvement over the inventor of the wheel.
          The big quiz:
          ...you did not follow the thread ... you are using critical damping .. you should be using laplace / heaviside
            Sorry Paul,
            but the idea is based on the same principle. I would love you to get the patent. As long as it isn't from Candy, it's OK for me!
            Go for it. Looking forward to see some improvements.
            • Aziz .. I would really like to tell you what it is ....but I am trying to....actually I am not sure what I am trying to do LOL ......
              Paul.
                The longer tail is a feature of prior art ... just lower level ... I am not sure it is a claim as such since patents should be focussed on methods that exploit phenomena not the phenomena itself ( since you cant invent physics or maths ). According to my advice even a sim could be challenged since it is only the result of mathematical manipulation of numbers by a CPU.
                moodz
                No you are right. I think you mentioned that minelab switch out the damping resistor so it would be prior art and the benefit of no damping resistor has been tried/ claimed before. I never suggested it should be a claim but explaining benefits (even if the benefit has been claimed before) helps convince the examiner that the patent has legs.
                Chudster
                  ...I am afraid its all over for the monocoil PI development .....
                  1. faster damping.
                  2. Automatic coil damping.
                  3. increased target sensitivity
                  4. near full depth discrim
                  5. Its a monocoil so it goes deeper
                  what more do you want .... ( oh yeh ... the cct )
                  I dont have to explain the picture below do I ???
                  [ATTACH]21043[/ATTACH]
                  The different waveforms are pretty clear for each case.
                  I'm afraid you do have one thing to explain for a Junior. Was it a very small Fe target and a very large non-Fe one? It does not seem right (but would be wonderful I suspect for mineralized ground) that the Non-Fe target response was larger than Fe if they were of similar size/ geometry.
                  It seems you have the principles right, real waveforms (not sims) and the circuit to match. I look forward to the circuit.
                  Chudster
                  • Originally posted by chudster View Post
                    Chudster
                    The discriminating effect is always present as long as there is current flowing in the coil.
                    With a ferrite target, that has no conductivity, the response signal is exactly 180 degrees from the response of a purely conductive target. (in the picture DOWN)
                    The response of a gold nugget will be UP.
                    A steel target has magnetic permeability like the ferrite, but also has conductivity like a non magnetic metal.
                    While there is varying current flowing in the coil (and the corresponding magnetic field of course) the response of the steel target will be both ways, DOWN and UP.
                    The amount of either UP or DOWN, will depend on the shape of the steel target. In very thin often rusty fragments of steel sheet, the 2 responses often cancel, or the resistive response is of higher amplitude. This is what makes the discrimination of these targets difficult.
                    With such targets, orienting them in line with the magnetic field lines, will enhance the reactive response and help therefore identifying them as ferrous.
                    Since the field lines on the edge of the coil have a different vector angle, this can be used to help discriminating for near targets.
                    Tinkerer
                    • Paul
                      1. faster damping.
                      I don't have to explain the picture below do I ???
                      could you unhook your special circuit and put the damping resistor back in, so we can really see how much of an improvement their is. all timing being equal of course
                      Philip
                      I'm not ready to put my white Pyjamas up on a stick yet.......I'll let ya know
                      • Originally posted by hdphilip View Post
                        Paul
                        Philip
                        Its a sim as I am not near the bench .... the params are for a 18 inch minelab mono coil.
                        PS ....
                        we dont want any naked developers ... this is a clothes on thread however you are permitted to run around screaming and pulling your hair out.
                        moodz
                          PS ....
                          moodz
                          [ATTACH]21050[/ATTACH]
                          So interpretation is that there is no operation of your circuit. Flyback time is greatly extended. Decay is (critically damped??) from the resistor only. If so that is as expected.
                          Maybe hdphilip you meant with Moodz' circuit and resistive damping (if that is possible) although Moodz says he has separate real and reactive elements with the load switched off near the 'undershoot' so maybe you are asking for the switch off not to happen?
                          Chudster
                          • chudster
                            i don't think moodz is switching anything, i mean, by the way of a mosfet, i suppose you could, let's review his clues....
                            here, i'll pm you my ideas, and see if the make sense with your ideas...
                            Philip
                            • I am thinking towards a matched impedance step up transformer to the mono M/L coil in the front end??
                              Sid
                              • It seem to me as if there is no transformation of a damping resistance to a target, hence decay is prolonged. Flyback, my ...
                                This very reason - resistance transformation - gave me impression that I'd get much more by step voltage excitation. After half a year I still think I'd get much more by step voltage excitation. Losses with PI resistor are just too great.
