Differential Coils ... Making
  • #46
    Hi Moodz, Thanks for responding. Thank was just my smarta*s Aussie humour. I've got a few different types of wire coming at the moment are I'm going to setup a series of coils to see if I can get the decay time down. I'll post up my results as soon as i've finished.
    I seem to have plenty of time at the moment, on holidays for the next 3 weeks.
    Mick
    • #47
      Just thought I would add this for interested persons
      a bit of colour helps
      6666
      • #48
        Knocked up a quick twisted pair coil
        useing pvc covered wire .5mm
        only had enough for 29 turns
        one winding gives about 410uH
        should be close enough I guess
        will get some more wire.
        • #49
          Hi 6666, it will be interesting to see how fast your coil is, the best I could get with a standard tight bound coil was about 22us, then I went to a spider coil and have got about 10-12us.
          Mick
          • #50
            Mick
            hmmmm ...I can sample at 6us and the coil is just "scramble wound" twisted pair.
            In fact to get good descrimination you need to sample very early.
            moodz.
            • #51
              moodz.
              At the moment i'm using your old frontend design with resistors and diode crowbar protection. I haven't been able to continue with the descrim frontend, because I ran out of blocking fets.
              Mick
              • #52
                Mick
                Fair enough ... I am ordering some alternative fets with 600 volt blocking.
                I will see how they go.
                moodz.
