Waveforms + Measurements
Originally posted by moodz View PostRepresentative waveforms at the output of the diff amp.
The pulse repetition frequency is quite high at 5.3 kHz however in this application the DSP code needs the high rate for adequate sensitivity.
I apologize if I'm missing something.
Originally posted by WM6 View PostAt which point of your FE schematic do you take out here displayed signals?
moodz
Originally posted by Tinkerer View PostMy guess is that the squiggle at the bottom of the Flyback is the reverse recovery of the diodes. If you try diodes of different recovery type, fast and hard or soft and slow, you will see a difference in the signal shape.
Tinkerer
Originally posted by moodz View Post...how does a relatively small target such as a 2 cm coin change this shape by 2 volts amplitude variation ????
When we clip the wave form and distort the shape with the diodes and opamp saturation, it makes it a bit more difficult to see the pertinent information about the target, but some of it is still there.
I think that your differential "mono coil" and preamp is a great idea and it is worthwhile to spend time on it to see how far ahead it can take PI development.
Tinkerer
Originally posted by moodz View PostThe inputs to the differential amplifier are fed off either side of the differential coil which will + and - with respect to the centre tap analogue ground.
To investigate this I disconnected the negative input to the amp and connected it analogue ground. The amplifier was now only amplifying the signal at the + input side of the coil. I could see that the "huge" signal I am getting for the target is right at the base of the decay which is practically vertical voltage drop. The diff amp will try to amplify the difference at the inputs ... somewhat obvious. If the decay on one input is slight slower than the other there will be a relatively huge voltage differential this is what is being amplified ... a slight difference in the + and - decays caused by the target.
How is this .... ??? ..... the collapsing magnetic field of the TX coil will cause an equal and opposite flyback in the two sides of the diff coil. However the collapsing magnetic field of a target will be opposed to the main field ... so it will induce a very small decrease of field in the one coil and a very small increase in field in the other coil thus producing an ever so slightly different rate of decay in the coils and a shift in balance which the diff amp detects.
Because the waveforms at each input are falling at a huge dV/dt at this measure point it only takes a few nano seconds of shift to generate 10s of mv of difference between the two diff signals thus relatively small targets produce relatively huge ouputs. By varying the damping resistor in the way I had it connected I was effectively balancing the two coils which even a small coin would unbalance to produce a target response. If the two coils are each damped independantly the decays of each side may be balanced by varying one side to produce a balanced condition. This is what I inadvertantly achieved with my variable damper which had an offset resistance.
Originally posted by KingJL View PostThe reason for the imbalance is because the inductances on each side of the differential coil are not equal. If you center tapped the coil (at ½ the total turns) then you have a turns ratio of 2:1 and an inductance ratio of 4:1 for the two sections of the autotransformer. If your desire is a balanced flyback signal on each leg of the differential coil, the center-tap should occur at .707 of the total turns giving an inductance ratio of 2:1.
Could we go back to the coil building and redesign it?
I want to try the differential coil with my differential front end, since many are asking for a mono coil system.
What are your suggestions for an experimental differential coil winding and TX circuit?
All the best
Tinkerer
Originally posted by WM6 View PostHi KingJL,
it is not clear to me how to explain this number 707?
Please more explanation!
I made the same mistake and did not realize what I had done until I really delved into why I had such an imbalance on the differential legs. You have to center-tap the inductance not the turns. It is the inductance that generates the flyback pulse with the collapse of the electromagnetic field. It is the flyback and subsequent decay that you want balanced to the input of the diff amp!
JLK
Originally posted by KingJL View PostThe reason for the imbalance is because the inductances on each side of the differential coil are not equal. If you center tapped the coil (at ½ the total turns) then you have a turns ratio of 2:1 and an inductance ratio of 4:1 for the two sections of the autotransformer. If your desire is a balanced flyback signal on each leg of the differential coil, the center-tap should occur at .707 of the total turns giving an inductance ratio of 2:1., this is not correct.
The imbalance is caused due to parasitic capacitance from to the TX mosfet. There are two parasitic capacitances, which will be seen by the active coil half:
Drain-Gate and Drain-Source path. The other coil half will see a different capacitive load however.
To make the capacitive load nearly symmetric, a symmetric TX Driver stage would be good. Even the other half is not active.
A center-tapped coil will have equal inductance coil halfs. The mutual inductances are of same amount.
Ltot = Lh1 + Lh2 + 2*k*sqrt(Lh1*Lh2),
Lh=Lh1=Lh2, k=1 (coupling coefficient)
-> Ltot = 4*Lh
Aziz
-> Ltot = 4*Lh
Aziz
The PI pulse is broadband and the results so far are not explained by analysis using lumped constants ... there is a whole new field opening here for detectors coils based on different configurations of coiled transmission lines where a broadband transformer is formed with the target / ground as the core / coupled element.
Some of my latest experimental results confirm this ... we have to move away from the simple inductive narrowband "transformer" analysis.
moodz.
Originally posted by moodz View PostAziz ... I agree with your analysis however is only valid for low frequency. The use of twisted pair ( bifilar ) in the differential coil actually behaves as a type of transmission line transformer. ( see my other post in theory section ... Ruthroff voltage balun )
moodz.
I suspect, that trying to process this ultra-short period wouldn't work in the field. You will have much higher ground effects.
Did you try it with a shielded coil? Does it behave the same?
Aziz
