DSPIC30F4012 v230 Source Code
  • #31
    code building ....
    For those building the code under MPLAB a good build should have an output like this ...
    note you can also see the tool versions in the output below ....
    regards,
    moodz
    Release build of project `C:\WORK\METAL\Metal23RELEASE\23001H\Metal23.mcp' started.
    Language tool versions: pic30-as.exe v3.23, pic30-gcc.exe v3.25, pic30-ld.exe v3.23, pic30-ar.exe v3.25
    Wed Sep 21 20:51:01 2011
    Clean: Deleting intermediary and output files.
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\main.o".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\serial.o" .
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\pwm.o".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\eeprom_rw .o".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\ADC.o".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\timers.o" .
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\vars.o".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\main_loop .o".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\RS232menu .o".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\QEImenu.o ".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\lcd.o".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\Metal23.c of".
    Clean: Deleted file "C:\WORK\METAL\Metal23RELEASE\23001H\Metal23.h ex".
    Clean: Done.
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "main.c" -o"main.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "serial.c" -o"serial.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "pwm.c" -o"pwm.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -c "eeprom_rw.s" -o"eeprom_rw.o"
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "ADC.c" -o"ADC.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "timers.c" -o"timers.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "vars.c" -o"vars.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "main_loop.c" -o"main_loop.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "RS232menu.c" -o"RS232menu.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "QEImenu.c" -o"QEImenu.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c "lcd.c" -o"lcd.o" -Wall -Os -legacy-libc
    Executing: "C:\Program Files\Microchip\mplabc30\v3.25\bin\pic30-gcc.exe" -mcpu=30F4012 "main.o" "serial.o" "pwm.o" "eeprom_rw.o" "ADC.o" "timers.o" "vars.o" "main_loop.o" "RS232menu.o" "QEImenu.o" "lcd.o" -legacy-libc -o"Metal23.cof" -Wl,-L"C:\Program Files\Microchip\MPLAB C30\lib",--script="..\..\..\..\Program Files\Microchip\mplabc30\v3.25\support\dsPIC30F\gl d\p30f4012.gld",--defsym=__MPLAB_BUILD=1,--heap=200,--stack=320,--no-check-sections,-Map="Metal23.map",--report-mem,--cref,--warn-section-align
    Program Memory [Origin = 0x100, Length = 0x7f00]
    section address length (PC units) length (bytes) (dec)
    .text 0x100 0x38e0 0x5550 (21840)
    .const 0x39e0 0x592 0x85b (2139)
    .text 0x3f72 0x86c 0xca2 (3234)
    .dinit 0x47de 0x294 0x3de (990)
    .text 0x4a72 0x734 0xace (2766)
    .isr 0x51a6 0x2 0x3 (3)
    Total program memory used (bytes): 0x78fc (30972) 63%
    Data EEPROM Memory [Origin = 0x7ffc00, Length = 0x400]
    _011012a04e79c198 0x7ffc00 0x1c 0x1c (2
    Total data EEPROM used (bytes): 0x1c (2 2%
    Data Memory [Origin = 0x800, Length = 0x800]
    section address alignment gaps total length (dec)
    .nbss 0x800 0 0x26 (3
    .ndata 0x826 0 0x20 (32)
    .nbss 0x846 0 0x8a (13
    .ndata 0x8d0 0 0xc (12)
    .nbss 0x8dc 0 0xc (12)
    .ndata 0x8e8 0 0x4 (4)
    .nbss 0x8ec 0 0x2 (2)
    .data 0x8ee 0 0x242 (57
    .dconst 0xb30 0 0x24 (36)
    .data 0xb54 0 0xa (10)
    .bss 0xb5e 0 0x2 (2)
    .data 0xb60 0 0x2 (2)
    .dconst 0xb62 0 0x2 (2)
    .data 0xb64 0 0x2 (2)
    .bss 0xb66 0 0x2 (2)
    .heap 0xb68 0 0xc8 (200)
    Total data memory used (bytes): 0x430 (1072) 52%
    Dynamic Memory Usage
    region address maximum length (dec)
    heap 0xb68 0xc8 (200)
    stack 0xc30 0x3d0 (976)
    Maximum dynamic memory (bytes): 0x498 (1176)
    Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-bin2hex.exe" "C:\WORK\METAL\Metal23RELEASE\23001H\Metal23.c of"
    Loaded C:\WORK\METAL\Metal23RELEASE\23001H\Metal23.cof.
    Release build of project `C:\WORK\METAL\Metal23RELEASE\23001H\Metal23.mcp' succeeded.
    Wed Sep 21 20:51:07 2011
    BUILD SUCCEEDED
    • #32
      updates and releases v23001 L and H
      Fixed a small limit bug in a timer prefix.
      Press zero button LCD splash screen now replaced by two second timeout splash screen ... the chip starts without you doing anything
      TWO hex releases .... TX is active high ( H ) and TX is active low ( L ) .... with respect to sample times.
      Pick the one that matches your mosfet drive circuit. ( hi = tx on OR low = tx on )
      Metal23_TX_H.zip
      Metal23_TX_L.zip
      Identical functionality except the TX signal is inverted on TX_L
      Now some timing info ... see pic below. ( this is from TX active low code )
      sample pulse 1 and 2 have been set to the extreme ends of a TX cycle ( ie TX on and off periods ) and minimum sample width ( 2 steps ). in this case the TX frequency is 4 Khz so the period is 250 us. The TX on time is 125 us ( adjustable from 0 to 250 us in 66 ns steps )
      The minimum width of a sample pulse is 66 ns ( no prize for guessing what the maximum width is ) ..... The minimum step increase in pulse width (ie sample resolution ) is 33 ns.
      So you should have no problem sampling wherever you want to during TX ON or OFF at any practical resolution, sample pulse width, TX frequency, TX pulse width ... ( is there something I forgot in that list ?? )
      moodz
      • #33
        inverting the sample pulse ....
        I tested this just to make sure ....
        lets say you have a 4 Khz TX frequency ( 250 us period ) and a 100 us TX pulse ( does not matter if it is the L or H version firmware ).
        If you set sample pulse 1 ON time ( S1 ) to say 105 us and S1 OFF time to 110 us then your sample 1 pulse will go high at 105 us and low at 110 us. ( ie 5 us pulse starting at 105 us which is 5 us after the TX turns off. Simple .. right !
        Oh dear ... what if your sample circuit wants an active low sample pulse ????
        Well all you do is swap the above settings around !!!
        set S1 ON = 110 us and S1 OFF to 105us and voila your pulse is inverted
        simple again !!!
        Using this method you can even mix and match S1 can be positive ( lo hi lo ) and S2 can be ( hi lo hi ) .... fantastic ... if thats what your sample channels want ...
        moodz.
        • #34
          I wish to undestand this: how ".. with respect to sample times."?
          Can you explain this by drawing? Thank you in advance!
          • #35
            ... a picture says a 1000 words.
            Answer for WM6 and maybe others ...
            Following parameters can be set from menu ( LCD or RS232 )
            1. TXF transmit frequency
            2. TXP transmit ON period.
            3. S1 ON sample pulse 1 on time set from start of TXP (T1 in diagram)
            4. S1 OFF sample pulse 1 off time set from start of TXP (T1 in diagram)
            5. S2 ON sample pulse 2 on time set from start of TXP (T1 in diagram)
            6. S2 OFF sample pulse 2 off time set from start of TXP (T1 in diagram)
            S1 and S2 can be configured for any on and off time during the period TXF including 0 and the maximum ( TXF ) so you can sample during TX or RX or both or disable by setting both to 0.
            TX pulse repeat at TXF frequency rate T1 , T2 etc
            Also shown how sample pulse is inverted but timing remains the same.
            moodz.
            • #36
              Hi Moodz
              thanks for the changes to software
              ordered some 30f4012 chips
              but it does not look like my current programmer and software supports 30f4012 chips
              so looks like i have to get a PICkit 2
              Does the PICkit 2 have its own separate programing software
              or can you program the 30f4012 direct from Mplab IDE ?
              I see a few pickit2 clones with all the chip adaptors on ebay but not sure about the programming software .
              thanks
              • #37
                Hi Moodz
                thanks
                Pickit 2 or 3 should come with its own programming software. However MPLAB supports it straight off the menu. So you can use either . Of course you need MPLAB to compile the code if thats what you want to do also. I have not tried the pickit clones but I did try an ICD2 programmer clone and it worked fine.
                moodz.
                • #38
                  Thanks for that info Moodz
                  had a poke around in mplab and found where you can select programmer
                  so lashed out and bought a pickit3 clone
                  I hope it works.
                  http://www.ebay.com/itm/ws/eBayISAPI...m=350492021662
                  • #39
                    I hope it works.
                    Hello 6666,
                    Some months ago I have bought one at the same Ebay site, works nice !
                    (for programming the logger chip)
                    From the ziff socket board I have removed the transparent protection cover...make's swapping the IC easier.
                    Best regards.
                    AP
                    • #40
                      Hi Ap
                      thanks thats good to know
                      cheers
                      6666
                      • #41
                        ....now we move into the overtaking lane.
                        A new menu item has been added to the UNIPI chip. User settable damping
                        It is usually not practical to set damping in the field ... The UNIPI can do it now ... select from menu and adjust for minimum signal using AIR ( ie coil not near ground ) .... or you could adjust it with the coil near the ground ( AIR + GROUND ) ... who cares ... do whatever you want .... its easy
                        Below we see shots of OVER, UNDER and OK damping. Below that is the LCD menu displaying the "goldilocks" setting.
                        ... some may ask ... but how will I know if the damping is set right in the field without a CRO ???? ..... well if you look at the pics below and lets say you were sampling at about 7 microseconds ( he he ... oh you noticed my nice coil speed did you ) the output of the preamp will either rail positive or negative depending on over damp or underdamp and this is what indicates by way of a very simple measurement whether you are under or overdamped.
                        Anyway ... if anyone is interested I could add some code to "autodamp" the coil which was going to be a feature on the UNIPI PRO but what the heck ... we can do it on this chip also.
                        These results were tested on a monocoil front end. This is the descriminating frontend that not only descriminates but also provides faster damping through elimination of parasitic capacitance ( sure to be a future topic of furious debate ). I have the circuit physically laid out for testing .. but I have not drawn it yet. The code on its own wont damp anything ..... so I will release it when the hardware drawings available and maybe a bit more testing on coil speeds etc.
                        moodz.
                        • #42
                          Hi Moodz,
                          You said in your last post" how would you know if the damping is set right, out in the field", from my experimenting the correct damping of a coil gave maximum depth to a test piece.
                          Maybe someone could confirm this!!!
                          Regards Ron
                          • #43
                            Originally posted by authere View Post
                            Hi Moodz,
                            Regards Ron
                            Hi Ron ... on most PIs the damping is not really a user control ...its kind of a bench setting ...in this design the damping is a user control and is actually critical for the unicoil design ...as you can't set the descrimination without it. The depth will depend on the damping but also sample timing amp gains and even threshold settings in the audio section.
                            Regards moodz.
                            • #44
                              I am one step closer, pickit3 arrived today, nice little unit
                              now for the other goodies.
                              • #45
                                I received my Pickit2 Clone today from Sure Electronics. It did not come w/software. I downloaded the MPLAB C Compiler from here: http://www.microchip.com/stellent/id...cName=en536656
                                Dave Frank
