I finally got the circuit built and it seems to function as mentioned except for one small problem, the frontend is a little deaf compared to a standard mono front end.
I end up taking the blocking fet circuit out and used a matched pair of 1k resistors and crobar diodes on the TX fet side then into a diff amp. My modified setup works fine, the TX is about 100us running about 400volts flyback and it's decay at the diff amp is about 6us.
Mick
Mick
