software exp 4000
  • software exp 4000
    hellp me iam software visualizer 3d download
    i have cracked visualizer 3d for you.please contact me
    [email protected]
      Im looking for a cracked version of visualizer 3d by okm for my future 2005 detector.Thanks
        WHO DO I HAVE TO KILL TO GET A CRACKED COPY?
        I would like to receive a copy. Want me to bark like a dog or yell like a chick? (forget the second choice!) [email protected]. Thanks in advance for yor reply.
          [email protected]
            [email protected]
            Beware!!! this lier charges 400 dollars for each copy.
              visualizer
              [email protected]
              Hi,do you still have a cracked visualizer 3d?Please contact me if yoy do.Thanks.
                Hi.
                I also am interesting for a free cracked visualizer 3d
                My email there is at forum.....
                  Visualizer 3D cloned
                  No cracked visualizer 3d, has just Visualizer 3D cloned see this video
                  greeting
                  http://www.youtube.com/watch?v=SNsa0RN9J0c
                    greeting
                    Hi mikipn
                    Thanks ,for pictures. My question , The picture show on screen from target,
                    Is similar to real target buried under ground ?
                    Best regards.
                      Hi Mikipn.
                      You have a nice open magnetometer with the possibility to work as gradiometr.
                      Clearly a So called "fluxgate" sensors.
                      Second harmonic amplified directly on the amplifier in the system as the 741st.
                      Coils only two opposite sides of the toroid winding excitation instead of a full - will be a little more EMI.
                      Distance between sensors of about 25cm will not increase the sensitivity of better than 10nT / m.
                      This equipment will help to find a tank buried under the earth - not quite deep.
                      But why call it the GPR?
                      Show images, software is certainly better.
                      Best regards Chris.
                        Originally posted by aft_72005 View Post
                        Hi mikipn
                        Best regards.
                        This picture was in exp 4000, I had an interest in Visualiser3D cloned and put into any PC and successfully did it. The sensor would have opened it could not forgive myself that I did not, (I have lots of pictures of OKM device open with which I had access)
                          Hi Mikipn.
                          Very good photos. Can you attach here more photos???
                            Originally posted by Krzysztof View Post
                            Hi Mikipn.
                            Best regards Chris.
                            Yes, it is perfect for fined big Ferro metals , but there isn't also good resolution picture on small
                            Size of metals , as example one coin . this is strange why saying 3D!!!!?? with this system we can
                            Scan two dimension .
                            when we can develop software , we can generate 3thed dimension . but it is not similar two real
                            target under ground .!!
                            I am interesting hear OKM designer reply in the mater . how much produced simulated picture
                            Seem as real target ??? the persons who working reality may be say reply .???
                              Hi Aft_72005.
                              Thank you for your interest.
                              Sam is also looking for 2 pieces of tanks from the Second World War buried in the swamp, and today the area of the water.
                              See the "VUMATE" - free, only the essence.
                              There you can test the emergence of the third dimension.
                              3D depends only on the measured value.
                              Best regards Chris.
