HH2 -- first cut
  • HH2 -- first cut
    For the most part, HH2 is the same as HH1 except that the main 555 oscillator and 74221 chips have all been replaced with a PIC 12F683. Why did I chose this part? Because it is small (8 pins), and offers the option of trying out the ADC and PWM for audio generation.
    Also, I did a few minor updates, namely adding a class B driver for the MOSFET, a drain diode on the MOSFET, and a feedback clamp diode. These should help those who are trying to wring out minimal sample delays.
    - Carl
    Here is a 150dpi GIF (PDF above is 300dpi):
      Here is the current layout:
        Please look over the schematic & layout and post feedback & suggestions. Keep in mind that this is not intended to be a cutting-edge design, but rather a circuit that introduces the use of a PIC for timing control. It is really meant for those who now understand PI basics, but have never used micros.
        - Carl
          One final note: Unlike HH1, I don't intend to offer PCBs for this project. It's just too time-consuming. But I will post Gerbers for anyone who wants to get a board made, and folks are welcomed to team up to cut costs, or even sell boards on their own. I recommend pcbcart.com for good quality cheap PCBs.
          - Carl
            Hi Carl,
            Thanks for your idea,
            Please tell us about PIC source program in basic or c++ and PIC micro exactly what do in this HH2 circuit?
            did we use the same PIC design for Deltapulse circuit ?
            With best regards...
              To my recollection, the Deltapulse does not use a PIC. In this design, the PIC controls the coil pulse & the sample timing. It is also possible to digitize the analog output and create a VCO audio using the PWM.
              The source code will be in C, using the free Microchip C compiler. I did most of the work on this project last year, including the microcode, but never got it finished. When I switched jobs a few months ago I managed to lose the source code, I think it was on my Maxim laptop that I turned in. So I am starting over on that, but it shouldn't take long.
              - Carl
                Hi Carl
                Why not to use a 1N4007 instead of 1N4004? The junction capacitance is about half...
                  Actually, I threw it in as a placeholder... I haven't researched low-cap diodes. The 4007 is probably fine.
                  - Carl
                    I like what i see on this schematic, also i like the way pcb is projected.
                    So... only code we need to start making this. Looking forward.
                    Regards!
                      keeping a keen eye on this one. looking forward to the source code.
                        MOSFET fast switch-off circuit proposal with FET's
                        Hi Carl,
                        I recently analysed the totem pole MOSFET driver of the HH. This can be optimized using small signal FET's (BS170/BS250). The proposed schematics below is optimized for fast switch-off. It improves the turn-off fall time and turn-off delay time compared to the BJT solution in HH.
                        The gate charge in the MOSFET IRF740 will be discharged through Q1 (2N2907). R40/R41 resistors can even be omitted.
                        The performance is almost equal to the standard fast switching MOSFET driver IC's.
                          I recently analysed the totem pole MOSFET driver of the HH. This can be optimized using small signal FET's (BS170/BS250)...
                          U14 And U15 in the offered scheme do not do anything (it can be removed). At the same time, in gate X7 it is necessary to put the resistor 10-20 Ohm (protection from latch).
                          By the way, diode U11 too does not carry out any useful function, only worsens switch (IRF740) characteristics in open state.
                            Here is the low cost variant (initiated from Andy) with same switch-off behaviour expect the switch-off delay is extended about 0.5 µs.
                            The diode and the BJT is important to discharge the MOSFETs gate charge. This cannot be omitted. Switch-on isn't important and can be delayed and be slow for our purpose.
                              Forgot to mention: Pay attention to the pulse logic level! It is changed with the low cost variant (inverting totem pole gone). So the micro should give right logic levels.
