HH2 Option 1 source code
  • #31
    Here are my results
    I am getting the main Tx pulse on pin 6 and the two samples on pin 2 &3
    code from post 1
    #define TxPulse GPIO1
    #define Sample1 GPIO5
    #define Sample2 GPIO4
    #define PWM GPIO2
    #define ADC GPIO0
    there are TWO drawings labelled Rev A1 20 June 2009
    The first drawing is the old one
    drawing 4 matches the code, see pdf
    • #32
      To burn the 12f683 I used a simple jdm programmer and Winpic800 software
      works very good for 12f683, the programmer (burner) cost a whole $18.00. The software is free, and has a lot of good features.
      http://www.ebay.com.au/itm/New-PIC-M...item415cb0ce7e
      http://www.winpic800.com//index.php?lang=en
      • #33
        please post complete shematic.pcb,and hex file.Best regards
        • #34
          Its all here in this thread
          • #35
            The source code is in post 1
            here is my hex file as a text file
            save and rename as carlcode.hex or whatever name you want
            the pcb mods are in the post above in the pdf
            • #36
              thanks
              • #37
                Altra
                could you please tell me how to change your code
                so I can change the TX pulse freq from 1000hz to 100hz ?
                but still leave it at 100uS pulse width.
                thanks
                6666
                • #38
                  6666,
                  The TX frequency is controlled by Timer 1 interupt. The frequency is set by changing the values for Timer1H and Timer1L. I just estimated the values below, no time to try it out. If you have problems, I can figure the exact value later this week
                  Change this:
                  ;Constants
                  Timer1H equ 0xFC ;Controls Tx Freq - TMR1 interrupt rate TMR1H
                  Timer1L equ 0x20 ;Controls Tx Freq - TMR1 interrupt rate TMR1L
                  To: Try these for 100Hz
                  ;Constants
                  Timer1H equ 0xD8 ;Controls Tx Freq - TMR1 interrupt rate TMR1H
                  Timer1L equ 0xF4 ;Controls Tx Freq - TMR1 interrupt rate TMR1L
                  Experiment with different values and watch the frequency change.
                  • #39
                    Thanks Altra will give it a try
                    cheers
                    6666
                    • #40
                      Altra would you mind if I ask another question please ?
                      If i wanted to invert the polarity of the TX and S1 and S2 pulses
                      that is making them go positive
                      is it just a matter of changing the H and L at these red points in the code ?
                      and would doing this mess up pin 7 ??
                      thanks
                      6666
                      ; Filename: HH2_PULSE_R2.ASM
                      ; Date: Jan, 2010
                      ; File Version: V0.2
                      ; PIC12F683 @ 8Mhz Intrc_osc
                      ; MPASM Assembler
                      ; Author:Mark Snyder/Altra Electronics
                      ; Notes: Circuit, HH2, PCB, Carl Morland, Geotech
                      ; TX pulse triggered on TMR1 interrupt, Tx 100uS @ 1000hz
                      ; Sample_Delay = ADC 0, 1.5uS resolution
                      ; Sample 1 = 15uS
                      ; Sample Spread =200uS
                      ; Sample 2 = 15uS
                      list p=12f683
                      #include <p12f683.inc>
                      radix dec
                      errorlevel -302
                      __config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _FCMEN_OFF)
                      ; Pin definitions PIC12F683
                      ; Pin 1 Vdd +5vdc Pin 8 Vss GND
                      ; Pin 2 GP5 Sample 2 Pin 7 GP0 AN0 Pot/Sample Delay ISP Data
                      ; Pin 3 GP4 Sample 1 Pin 6 GP1 AN1 TX_pules ISP CLK
                      ; Pin 4 MCLR Pin 5 GP2 PWM Out
                      ; #Defines
                      #define TX_PULSE GPIO,1 ;PIN 6
                      #define SAMPLE_1 GPIO,4 ;PIN 3
                      #define SAMPLE_2 GPIO,5 ;PIN 2
                      ;Constants
                      PR2_con equ b'11001111' ;PWM
                      CCPR1L_con equ b'01100111' ;PWM
                      CCP1CON_con equ b'00111100' ;PWM
                      T2CON_con equ b'00000111' ;PWM
                      ;Variables
                      CBLOCK 0x20 ;Reserve Ram for Variables start 20h
                      w_temp: 1 ; variable used for context saving
                      status_temp: 1 ; variable used for context saving
                      SAMPLE_DELAY: 1 ;Sample Delay Variable
                      AD_LO: 1 ;ADRESL Var
                      AD_HI: 1 ;ADRESH Var
                      temp1: 2 ;Temp Variable
                      endc
                      org 0x00 ; Reset vector
                      call SetupPWM ; To disable PWM ";" this line out
                      goto main ; Go to beginning of program
                      org 0x04 ; Interrupt vector
                      movwf w_temp ; Save off current W register contents
                      movf STATUS,w ; Move status register into W register
                      movwf status_temp ; Save off contents of STATUS register
                      ; check for TMR1 rollover
                      banksel PIR1
                      btfss PIR1, TMR1IF ; TMR1 rollover?
                      goto Jump_ISR
                      banksel TMR1L
                      movlw Timer1L ; Reload TMR1
                      movwf TMR1L
                      banksel TMR1H
                      movlw Timer1H
                      movwf TMR1H
                      ;Interupt Service Routine******************************************* *******
                      ;TX_PULSE
                      bcf TX_PULSE ;GPIO.1 Low
                      movlw .67 ;67 x 1.5uS = 100.5uS Tx pulse width
                      movwf temp1
                      decfsz temp1,1
                      goto $-1
                      bsf TX_PULSE ;GPIO.1 High
                      ;Sample Delay
                      movfw SAMPLE_DELAY ;((0 to 255) x 1.5uS )+ 1 = 3 to 383uS
                      addlw 0x01 ;Sets minimum sample delay-never zero
                      movwf temp1
                      decfsz temp1,1
                      goto $-1
                      ;Sample 1
                      bcf SAMPLE_1 ;GPIO.4 Low
                      movlw .10 ;10 x 1.5uS = 15uS Sample
                      movwf temp1
                      decfsz temp1,1
                      goto $-1
                      bsf SAMPLE_1 ;GPIO.4 High
                      ;Sample Spread Delay
                      movlw .133 ;132 x 1.5uS = 199.5uS Spread between samples
                      movwf temp1
                      decfsz temp1,1
                      goto $-1
                      ;Sample 2
                      bcf SAMPLE_2 ;GPIO.5 Low
                      movwf temp1
                      decfsz temp1,1
                      goto $-1
                      bsf SAMPLE_2 ;GPIO.5 High
                      ;END ISR*********************************************** ********************
                      ;Restore registors -Reset Interrupt flag
                      banksel PIR1
                      bcf PIR1, TMR1IF ; clear interrupt flag
                      Jump_ISR
                      movf status_temp,w ; retrieve copy of STATUS register
                      movwf STATUS ; restore pre-isr STATUS register contents
                      swapf w_temp,f
                      swapf w_temp,w ; restore pre-isr W register contents
                      retfie ; return from interrupt
                      ;Initialize
                      main
                      banksel OSCCON
                      movlw b'01110101' ;SET INTERNAL OSC TO 8MHZ
                      movwf OSCCON
                      ; Set up direction of GP I/O pins
                      banksel TRISIO
                      movlw b'00000001' ;GPIO.0 AD INPUT, GPIO 1 TO 5 OUTPUTS
                      movwf TRISIO
                      ; Set up comparator
                      banksel CMCON0
                      movlw b'00000111' ;COMPARATOR OFF
                      movwf CMCON0
                      ; Set up A/D converter
                      banksel ANSEL
                      movlw b'01010001' ;FOSC/16-GPIO.0=AN0
                      movwf ANSEL
                      banksel ADCON0
                      movlw b'00000001' ;AD result left justify, 8bit resolution
                      movwf ADCON0
                      ; Initialize interrupts
                      banksel INTCON
                      movlw b'01000000' ;Enable peripheral interrupts
                      movwf INTCON
                      banksel PIE1
                      movlw b'00000001' ;Enable TMR1 overflow interrupt
                      movwf PIE1
                      banksel PIR1
                      movlw b'00000000'
                      movwf PIR1
                      ; Initialize TMR1
                      banksel T1CON
                      movlw b'00010101'
                      movwf T1CON
                      ; 8 MHZ internal oscillator
                      ; Fosc/4 = 2 MHZ = 500nS per clock
                      ; with 1:2 prescaler
                      banksel TMR1L
                      movlw Timer1L ;0x20
                      movwf TMR1L
                      banksel TMR1H
                      movlw Timer1H ;0xFC
                      movwf TMR1H
                      banksel INTCON
                      bsf INTCON, GIE ; enable interrupts
                      ; Loop until next TMR1 interrupt
                      Idle_loop
                      bsf ADCON0,0 ;ADC on
                      nop ;Delay
                      nop
                      nop
                      nop
                      nop
                      nop
                      nop
                      nop
                      nop
                      nop
                      bsf ADCON0,1 ;Start A/D conversion
                      btfsc ADCON0,1 ;AD complete skip
                      goto $-1 ;loop
                      banksel ADRESH
                      movfw ADRESH
                      movwf SAMPLE_DELAY ;Store AD hibyte
                      banksel ADRESL
                      movfw ADRESL
                      movwf AD_LO ;not used
                      bcf STATUS,RP0
                      goto Idle_loop
                      SetupPWM
                      ; Initialize PWM
                      banksel PR2
                      movlw PR2_con ;b'11001111' ;600hz 50%
                      movwf PR2
                      banksel T2CON
                      movlw T2CON_con; b'00000111' ;600hz 50%
                      movwf T2CON
                      clrf CCPR1L
                      movlw CCP1CON_con; b'00111100' ;600hz 50%
                      movwf CCP1CON
                      movlw CCPR1L_con; b'01100111' ;600hz 50%
                      movwf CCPR1L ;
                      return
                      END
                      • #41
                        6666,
                        TIMER1L and TIMER1H only affect the TX frequency. See post #38. The reason there is an L and H is because it is a 16 bit register. But the pic chip is only an 8bit device. Therefore to read and write to this register it takes two operations. A (H)igh byte and a (L)ow byte.
                        To change the the polarity of the TX and samples. There are two commands bcf and bsf. bcf sets the pin to low or 0. bsf sets the pin high or 1.
                        bcf = bit clear in f ............ bsf = bit set in f
                        If you want to change which pins are assigned to sample or tx change these
                        (original)
                        ; #Defines
                        (with samples reversed)
                        ; #Defines
                        #define SAMPLE_1 GPIO,5 ;PIN 2
                        #define SAMPLE_2 GPIO,4 ;PIN 3
                        Try this, I reversed the polarity of the Tx and samples. All I did was changed the bcf's to bsf's and bsf's to bcf's.
                        ;TX_PULSE
                        bsf TX_PULSE ;GPIO.1 high
                        movwf temp1
                        decfsz temp1,1
                        goto $-1
                        bcf TX_PULSE ;GPIO.1 low
                        ;Sample Delay
                        movwf temp1
                        decfsz temp1,1
                        goto $-1
                        ;Sample 1
                        bsf SAMPLE_1 ;GPIO.4 high
                        movwf temp1
                        decfsz temp1,1
                        goto $-1
                        bcf SAMPLE_1 ;GPIO.4 low
                        movwf temp1
                        decfsz temp1,1
                        goto $-1
                        ;Sample 2
                        bsf SAMPLE_2 ;GPIO.5 high
                        movwf temp1
                        decfsz temp1,1
                        goto $-1
                        • #42
                          Hi Altra
                          thanks for the reply, much appreciated
                          I can see what I need to do now
                          and will give it a try
                          cheers
                          6666
                          • #43
                            Hi Altra
                            thanks it works
                            had a bit of a hard time compiling the code this time
                            finally got it compiled in mplab asm, it gave me lots of warnings
                            but it works, pin 7 works ok for the sample delay to
                            cheers
                            6666
                            here is the hex if anybody wants it
                            its altra's code moded to give positive going pulses
                            :020000040000FA
                            :040000006B20322817
                            :08000800A0000308A10083120F
                            :100010000C1C2D28831220308E008312FC308F00A0
                            :1000200085144330A500A50B132885102208013E36
                            :10003000A500A50B192805160A30A500A50B1E283A
                            :1000400005128530A500A50B232885160A30A500CA
                            :10005000A50B2828851283120C1021088300A00EFE
                            :10006000200E0900831675308F008316013085003D
                            :10007000831207309900831651309F00831201309C
                            :100080009F00831240308B00831601308C00831256
                            :1000900000308C00831215309000831220308E00C7
                            :1000A0008312FC308F0083128B171F140000000096
                            :1000B0000000000000000000000000000000000040
                            :1000C0009F149F18612883121E08A20083161E0821
                            :1000D000A300831255288316CF3092008312073075
                            :0E00E000920093013C309500673093000800B9
                            :02400E00D433A9
                            :00000001FF
                            • #44
                              Cheers for posting hex,and thanks to Altra for his quick reply and re-asm.
                              A question for 6666.
                              What was the reason to change frequency...are you hunting the holy yellow grail?
                              and Merry Xmas to all
                              John
                              • #45
                                Hi John
                                your welcome for the hex, I use a jdm burner for 12f683
                                re the Freq I am just experimenting with some ideas
                                and the 1000 pps was a bit high, BTW the above hex is still 1000 pps
                                ; Sample 1 = 15uS
                                ; Sample 2 = 15uS
                                cheers 6666
