I got stuck on this step:
IC5, IC11, IC12 are all ok -5v. But with TP1 i get at minimum of 0.04v to maximum 0.71v when i adjust the pots... (SW1 shorted)
Here is my circuit:
https://imageshack.us/a/img823/539/20130504210044.jpg
Any ideas what could be wrong? Or maybe it's just my DMM really inaccurate?
Power up the
circuitry again, and measure the supply
voltages on IC5 (pin 1 = -5v), IC11 (pin
8 = -5v), and IC12 (pin 8 = -5v). The
output of IC5 (TestPoint 1) should measure
slightly negative, and vary with the
Frequency and Pulse Width adjustments.
It should fall between -0.25 and
-1.25 volts, and be roughly -0.5v with
both adjustments centered.
Here is my circuit:
