My radio receiver chip came in at work, so I've had little time for anything else the last couple of weeks. However, on the PI design I had been wrestling with a strange coil pulse phenomena that defied explanation.
Basically, I was getting a negative overshoot on the coil waveform during flyback, as if the coil was slightly underdamped. I tried several different damping resistor values, and could change the overshoot, but could not make it go away. Well, last night I thought, "maybe it's the o-scope," so I switched the probe to the B-channel and the problem went away.
So, it looks like the design is final, and once I make a couple of tweaks to the PCB I will send out for some boards. Sorry for all the delays.
