Power supply voltage PI 1
  • Power supply voltage PI 1
    I would like to know if 10.68 volts is o.k. for the ic #2 pin #3 voltage, thats what I get when I checked it. I know Carl said around 12 volts, I'm thinking maybe its to low and maybe I need to check connection and components. Thanks William
    Re: Power supply voltage PI 1
    I think is low, check the power battery. but the ic2 work with 7 at 30 volts and think its is sufficient.
      The output voltage of ic#2 is 4.98 , I think this is o.k. Thanks William
        Yep, should be just fine. Ideally, if the battery voltage is exactly 12v, and there is no load current, you would get 12v.
