So i built the hammerhead Following the procedures on the PDF provided in Geotech1.
It works!!!!!
I can find coins, pulltabs and more. The only problem is that i can only find those objects at around 10cm and i have seen people finding objects at around 25 or even 35cm. I have tried to play with the pulse width and even changed the resistors to be able to have long pulses but i usually tested the circuit with pulses at around 50us to 100us, changing the frequency from around 615hz to 1500hz, playing with the delay time from 10us to around 60us, sample width at around 20us to 35us.
i even tried changing the resistor on the first amplifier. that is suggested to reduce the gain (2k resistor instead of 1k).
All of those settings did change the depth of detection, and even gave me better results but not as good as i seen on the forums.
Ok now lets go to the coils which i belive is one of the most important parts because if they fail, even the best circuit will not give anything. So i tried coils from 20cm to 35cm all of them worked but like i said the same depth was achived with any coil. i used enamel wire that i bought from a transformer factory and i have tried many different gauges of wire. from a thicker 24awg to even 30awg. I tested their inductances (from 300uH to 500uH). I have read another PDF about "fast coil" and even created a shield following the indication to Not complete the loop around the coil and short the shield. i am also using coax cable used from radio comms/ television its a white cable with a solid core of copper and a braid around it.
so i wanted to see if anyone still working on that project could help me. Ah i almost forgot, yes i did remore the components needed to calibrate the op amps (exacly like the procedure explained in the PDF).
sorry if my english isnt good enough, please ask me questions so i can try to explain a little better if needed.
Any help will be appreciated.
It works!!!!!
