I'm working on a Hammerhead hybrid using a PIC for timing, settings input & display. I want to use a non-VCO audio option. I will need to chop the final amp ouput with the PIC. But I'm not completely sure what the chopping actually does. I suspect that it squares the amps output to provide a dynamic signal for the audio amp?
Also does anyone know of a bilateral switch other than a 4066 that has a lower on resistance with a bipolar supply?
Regards Kevin
Regards Kevin
