Hammerhead PCBs are in...
  • Hammerhead PCBs are in...
    ..and they look real nice. $10 shipped in the US/Canada/Mexico, likely $12 shipped elsewhere. Paypal, check, money order, cash, or chickens. Payment can be made/mailed to:
    Geotech
    PO Box 184
    Oak Ridge, NC 27310
    With prior PCB orders, I included a copy of the full article, plus schematics & parts placements. The new article for this rev is not done (heck, it's not started), so I will not include the article print.
    Re: Hammerhead PCBs are in...
    Carl are there any differences between this board and the first one?
    Beachcomber
      Carl
      Check in the mail tomorrow.
      Ray
        Differences, yes...
        I've removed some option jumpers that gave the first design a lot of flexibility. The preamp is only set up for inverting gain, and the clock into the monostables cannot be inverted. This also removed the analog inversion option between the final amp and the audio.
        The reason I did this, was because it was too damn confusing, and did not add a whole lotta learning value. I replaced some of the freed-up area with extra pads, so that you can experiment with adding whatever extra parts you want. Mostly around the preamp.
        Also, I added a way to sync the 7660 off the main clock. And made some minor mods to the audio. And replaced all the preamp offsetting options, with a single universal offset. And cleaned up the layout a bit.
        The new boards are the same physical size as the old (3.5" x 4.0") but they do have a solder mask applied, which makes soldering errors & shorts less likely, and makes 'em prettier!
        Those who want to pay via Paypal, can use [email protected].
          New PI-1 PC board, surface mount?
          Hi Carl,
          Very very nice job!!!!!
          I'm very excited to know when the production pcb for new PI-1 PC board, surface mount while be available. Have you an idea?
          PhilippeM
            Thanks Carl. I am going to order oen of the new ones myself Plus I am still interested in the SMD version of the PC board when it's ready.
            BC
              Hi Carl,
              Great to see some hardware one can buy--but do not know much about the HAMMERHEAD--PLEASE
              Can it be used for nuggethunting???
              Thanx
              Chris
                As it is set up, I doubt it will do well on nuggets. Reg Sniff has a lot of experience on nugget hunting with PI's, so he might know how to tweak one up for decent results.
