Ok, good going.
Threshold Pot doesn't work
Originally posted by Carl-NC View PostDamping resistor power dissipation will double if you double the pulse rate.
Design a better audio driver. For example, you could use an LM386.
Dear Carl.
Can you suggest me some MOSFETs for Q3 (IRF740) which can be able to tolerate higher temperature?
Thank you all for your help.
Unfortunately, heat sink gets very hot because i'm using high pulse with for my HHD+GB.
I checked RDs of FQA11N90, it's like IRF840. I already used IRF840, it worked.
Do you think it works if i use on my HHd?
Thanks.
http://www.farnell.com/datasheets/17022.pdf
I have found that the performance of MOSFET switches is difficult to gauge by the data sheet, you have to buy & try.
There are 2 mechanisms that create power in the switch. First is the turn-on time, for that you want low RDS, especially if you are using a wide pulse width. Second is the flyback region if the MOSFET breaks down so to avoid that you want a high BVDSS. In most PI designs the avalanche is the biggest heat generator which is why I said to get a higher breakdown. But you should also pay attention to RDS, it's pretty easy to calculate what that power will be. Remember to include the coil resistance.
Originally posted by Carl-NC View PostI have found that the performance of MOSFET switches is difficult to gauge by the data sheet, you have to buy & try.
Dear Carl.
Yesterday, i received the MOSFET and tested over my HHD.
It works but has a problem. Since its current is high, i can not set frequency of my machine to 1KHz because my BAT LED will turn up.
So, i have to decrease frequency near to 850Hz. I prefer to obey Mr. Altra's advice, using larger heat sink for IRF740/840.
As you know, i added GB to my HHD and set its delay to 8us. I built a coil that is able to work at the delay (Teflon-AWG22-silver, it's wire of TDI Coil), i didn't used any spacer. The Coil works vey nice at the delay in a fixed state without movement so that its sensitivity is vey excellent (My TP4 form is clear). For shielding (Faraday Shielding ), i used a vey very thin copper foil, but i have a problem. Unfortunately, my machine will have action as soon as moving coil (left/right or up/down). This is only at the low delay, not at high delay.
Do you think this is because of changing coil capacitance? Do you have any suggestion for eliminating this effect?
I think i should use a thicker foil. Some people told me i must use only Graphite Spray!
Do you have any suggestion?
Thanks.
Originally posted by h9361 View PostHello
Dear Carl.
Thanks.
