Threshold Pot doesn't work
    Since i'm using a sealed acid battery (12V-1.2A), do you think it's because of its ampere?!
      Is there an easier way to use 8R speaker for VCO?!
        you need basic electronics course? nobody here is not academic, we are just beginners.
        use a transformer. get a current on the speaker converted from input voltage.
        please read the books related electronics more.
          Thanks, do you think 32R can work over HH1? I'm trying to find such speaker.
            i can find 50R speaker in chinese e-shop. by two clicks.
              https://www.aliexpress.com/item/4000...cfc2e0a8b9f6-8
              32 ohm
                https://www.aliexpress.com/item/4000...ed93646261c4-1
                50 Ohm!
                  Thanks, but buying from china takes a long time to arrive.
                    After a lot of trying, i found a 32R-0.25W speaker in my country, is it OK?
                    https://aliexpress.ru/item/4001275755654.html
                      i do not know your state be cause you do not want to fill a profile.
                        Dear Surfdetector, since you have tested HH1 with 32R speaker, do you think 32R-0.25Watt can work?
                          OK, i will fill my profile.
                            I made the Hammerhead 1 with the VCO option and had no problems with the circuit as designed. I used 32 ohm headphones.
                              Thank you.
                              I have a question about R10. Suppose that i have not connected coil to unit, is it possible to burn R10 or IRF740 if i touch pin-coil of unit?
                                close R10 by wire jumper and try to get working board.
