Hi All,
I finally got around to building up a HH PI. Initially, the decay curve was such that I couldn't use a delay much below 16 usec or so. I might have been able to reduce it some by adjusting my damping resistor which was at 800 ohms, but decided to try something different. I had selected an 800 ohm resistor in hopes that my coils built for my GQ clone would work.
Made a simple mod and changed R12 from a 1K to a 2.2K. Now I was able to use the minimum delay which was about 10 usec. I was using coils I built for my modified GQ clone and they worked about as well on this PI also. I forgot to mention that I am not using the 740 FET, but am using a FQPF 2N 30. this FET has an on resistance of about 3 ohms or so. What caused me to select this FET was the low capacitance values it displayed.
I also modified the HH so I could use a DD coil. This is a very simple thing to do.
I wasn't satisfied with the sensitivity of the HH to small gold so I increased the sensitivity of the diff amp and the autotune amp. I also expanded the range of the frequency by changing the 100K to a 250K pot.
Sample width was tried at various widths and I finally left it about 10 usec. I might reduce this some, but not much. Reducing it much will reduce the gain. Increasing the sample width seemed to increase the noise level.
So far, the HH doesn't perform as well as my modified GQ clone, but it does quite well. Detection of a 5 grain nugget is about 3" using a 11" DD coil. A nickel range was a little over a foot.
This isn't bad for a home built PI project. It is not complete yet, by so far all has worked out quite well. I would like to change the audio though. Still giving that some thought.
Reg
Reg
