I finally finished my stock HH and got it working (sort of). I am using a 500uh(498uh measured) 7.25" diameter coil, 26AWG, shielded. My coil is hooked up to the board via dual conductor shielded microphone wire. The shielding is grounded to the battery ground. When I power it up the threshhold pot really doesnt effect tunning very much, pulse width and freq have a lot more impact. Anyway, once I tuned it for just a few minutes I can detect my platinum/gold wedding band at 11". I am very happy with the early performace of this unit. But for some reason, when I hold the ring close to the coil (5" or so) the things frequency goes super high and stays there until I remove the ring. I thought it was supposed to stop if the coil was held still over the target and only do stay high when the autotrack was on. I still have not inserted a switch to use that part of the circuit. What could be causing this? Should I increase the value of the threshold pot as well? I am doing this in my apartment where I have a wireless router and alot of other noisey electronics.
Thanks for the help guys!
Will
Will
