[Newbie] C10 position
  • [Newbie] C10 position
    Hi all,
    I cannot find the "C10” place for welding 1000 µF capacitor onto the PCB.
    Herewith an image of my PCB:
    In advance thanks, if somebody can help me to put "C10” in the right place
    Sorry for my very bad English, I am French (nobody is perfect)
    Shaders
    C10 mounts on the back side of the PCB, and there is no silkscreening on the back side to show this. Because it is a rather large cap, I bend the leads 90 degrees and lay the cap flat against the board.
    - Carl
      Thanks again carl you're a chief
      If I include/understand you well, it would be necessary that I weld "C10" onto the backside of the PCB.
      Like this:
        I think the "negative" pad is correct, but the "positive" pad is the one due south, in the ground plane (actually -VB).
        - Carl
          Thanks again Carl
          ok for the negative.
          i will connect the positive on the –VB.
          It will look like this:
          Sorry for the step by step
          thanks again
            That's correct, but my brain had a momentary lapse... that's not the -VB plane, but the ground plane. The north side of R10 is -VB. Sorry.
            - Carl
              Thanks again Carl
