Are you sure that Q11 / page2, opt.2/ must be NPN ???
HeY Carl !
If Q11 is NPN, then Q7/Q11 form an SCR-type circuit. If Q11 is PNP, then Q7/Q11 form two stages of common-emitter amps... problem is, Q7 will need a resistive collector load, and Q11 will likely be biased 'on' all the time, unless some other measures are taken.
Short answer is, yes, Q11 should be NPN.
