any pcb
  • any pcb
    Hi Carl. When can i expect PCB of Hummerhead i ordered 4 weeks ago?I've sent You cash buy mail,and i am eating my nails waiting for PCB did You recive it?
    greetings
    It could be in my pile of mail, unopened. Email me your address and I'll go ahead and send the PCB. Specify thru-hole or SMT.
    - Carl
      Thanks Carl, You are the BEST.Can't wait for pcb
      and Merry Christmas!
        Hi Carl
        Yesterday a have recived a pcb of HH.looks great,piece of art!cant wait to start buiding.
        Thank You very mutch,and sorry for rushing
        best regards
        Igor
          Hi Carl,
          I started to build HH but in power circuit I have experienced some problems. I am using AC/DC adapter to get 11V for power supply. I am getting voltage readings on IC2 pin1, IC3 pin3, IC4 pin3 the same voltage like power supply 11V or a little less, not +/- 5V like I should.
          What could be the problem?
            Put your multimeter ground lead on the circuit ground, i.e., IC1-pin8. Measure -VB (IC1-pin3)... you should have -11V to -12V. If you measure a positive voltage you have the adapter polarity backward.
            Now measure IC2-pin3, the input to the 7805. You should read +10V to +11V. If not, IC1 might be bad. Also watch the polarities of IC2, IC3, and IC4. Also cap polarities.
            - Carl
              Hi Carl,i found my mistake.switch was bad.now i am geting 4,9 V. +- where needed,with 11 V power.thet seems OK?
