Hi Carl,
I need a small bit of confusion cleared up before I can proceed with assembling the timing circuit; I hope you can help.
The parts list shows the following:
Resistors: R46 - 10k, R46a 330
Pots: R46 10k
And the paragraph under the 'substitutions' section regarding pulse timing (top center of page 12) states that for a potentially more practical range of 3-20 us, make R46 2k and R46a 220.
Thing is, on the schematic, the R46 pot is depicted along with R46a but there is no 'second' R46 depicted for the application of the R46 10k resistor listed in the parts list... nor any pad available for it on the SMT PCB.
I'm just trying to determine if the part listing of an 10k R46 resistor was an error so that, if I decide to make the substitution, I can be sure I should be replacing the 10k pot with a 2k pot rather than a surface mount 10k resistor that isn't identified (or is there but I'm just not seeing...) that should be replaced with a 2k SMT resistor.
regards,
Malac
Pots: R46 10k
regards,
Malac
