amplifier for the near deaf
  • amplifier for the near deaf
    Hi carl
    can you provide an amplifier for my HH .. I am near deaf ....
    Just need to boost the amplifier a little bit ..
    thanks
    rob
    Rob
    I think I answered this before. I use a vibration motor in my underwater MD. It works well and vibrates my hand as I sweep over an object. Now you can not just hook it to the speaker output. You need to build a bias circuit, that varies the voltage as a signal is detected. It increases voltage to a max of three volts at full buzz. You can not tell the frequency (like the high pitch one you get when you move over, say, gold). I think a second circuit could be added to tell the freq. It could turn on and off at a different rate for different objects. I'm thinking of working on that. I also added a few leds to give a visual effect of the MD. I have great hearing but underwater headphones are to expensive for me, hence the vibrating motor.
    I got mine at ALL Electronics and look under MOTORS.
    This is the one I got:
    Low voltage, low current miniature vibrating motor. Operates on 1.5 - 3 Vdc @ 62 mA. Tiny motor with offset weighted shaft is used in cell phones and pagers for vibrating alert signal. A removable black rubber boot surrounds the motor and provides a flat mounting surface. Without the rubber boot the motor measures 0.24" dia. x 0.5" long. The shaft and weight add an extra 0.21" to the overall length. Prepped with 0.42" long metal tabs.
    CAT# DCM-204
    Your Price: $1.25 each
    Nice price, but you need to be very good with your iron and with SMT devices.
    Good Luck Rob
      You can get a motor from a discarded device.
        That is true, look around for an old pager. That is what the motor I stated above came out of (new stock). Make sure it's a pager that uses one AA battery (1.5 VDC), that way you will have a 3 volt motor.
        Good Luck
          Crystal earpiece
          Try a crystal earpiece sold by many electronics stores. They are very loud and consume very little power as they are designed to be used in a cystal set that has no power supply at all !
