HammerHead Power
  • HammerHead Power
    Hi to all,
    I made HH 3month ago, It was working very weak.
    Now I tested the current and voltage of it's coil, they are 130mA & 14v only!
    where is the problem?:confused:
    My HH workes almost 2w!
    I don't understand... the coil "on" current is 130mA? The flyback peak is 14V?
      Hi
      Yes,It is.
        Could be several things... have you looked at the gate drive waveform? If it's weak that could cause what you're seeing. Also, try removing R12 to see if there is a load problem. As always, recheck component values and look carefully for solder shorts.
        - Carl
          Waveform
          This is the TP2-waveform of my HH2:
          Where is the problem?
            New
            Hi Carl,
            These are waveforms of my HH:
            When I put the Freq at max, Q3 gets warm:confused:
            Please help me
            Thank you
              TP6?
              Tp6:
              TP7:
                It's hard to tell from this... What kind of scope are you using? Looks low-bandwidth, and may not be getting the transient flyback. In any case, TP2 looks wrong, and the gate drive looks sluggish. Did you double-check all component values? Look for solder shorts?
                - Carl
                  Hi
                  I checked all component values,they are correct & PCB doesn't any solder short.
                  In my scope the TIME/DIV is 200us & VOLT/DIV is 5V.
                  Does the TP6-Waveform look correct?
                  :confused:
                    R15
                    Hi Carl,
                    R15 should be omitted or not? (In the HH opt2)
                    I did not omit it.
                      R15 should be shorted?
                        R15 should make no difference. No, TP6 does not look right. See the HH article for what you should expect... there are waveform pics at the end.
