Hi Exciter,
The LM318 should work. If you can't zero the amp, then as you said, you might need to change the values of the resistors you mentioned. You could reduce the value of the 1 meg. This large of a resistor could cause extra noise also. So, you might try a lower value of one, maybe a 100K or so.
Keep in mind that the LM 318 will be noisier than the NE5534A. So, when trying to hear the very weak signals, the noisier IC will cause more problems.
Reg
Reg
