Ok,
Now, we have a new problem. You should have a signal that goes positive that isn't there.
Adjust your pulse width pot to maximum resistance and see what happens to the pic. This should give you a pulse width of about 75 usec.
Do you have the scope ground connected to the HH ground?
We still need to make sure everything is correct. Once I know the scope ground is connected to the HH ground and I see a pic of TP 4, I will be able to tell more. From what I see now, I am not sure why your pic doesn't look right. Maybe it is because the pulse width is at minimum. That is why I want you to adjust for maximum pulse width.
Reduce the sensitivity of the scope so the signals are smaller just to make sure the signal I am looking for isn't cut off.
Reg
Reg
