Carl,
As you know, I am starting a new Hammerhead project. I will put the project outlines and initial system design to this forum shortly (when I nail down a couple of key decisions). One of the key requirements is to optimize low noise capabilities of the front end. Since I will be using multiple HH boards in the implementation, I wish to break the front-end into two stages. It will be a low noise preamp running a relatively low gain, followed by a a seconday amp (on the second board) to make up a total front end gain of around 1000. The gain in the second stage will be controlable (range to be determined).
To that end I am looking at a AD797 runing non-inveting with a gain of 10 for the 1st stage. Also the input resistor (currently R12 in the single board) needs to be no more than 100 ohm to take advantage of the AD797 low noise(ref. AD797 spec. sheet). The second stage of the preamp is currently planned to be a AD8031 inverting with a gain of about 100.
Enough for now as I want to focus on this issue of the pre-amp. The question is what are the issues (other that the obvious physical interconnection issue) that I have not forseen?
J. L. King
J. L. King
