Hey again, all. I was looking at opamps for the front end of the HH (IC6 - NE5534) and began to wonder just which specifications are the most important. The top three seem to be bandwidth, input noise, and slew rate. Are there others that need to be considered? Which parameter is the most critical, the next, and so on? I have a few LME49710NA's to try 'cause it seems to me ->Ne5534: BW=11mHz, Noise=4nV/sq.Hz , Slew=13v/uSec Whereas -> LME49710: BW=55mHz, Noise=2.5nV/sq.Hz, Slew= 20v/uSec.
I wondered if I'm looking at the right things when considering other opamps. Is the slew rate that important, or the noise levels more so? Seems like anything over 1mHz on BW ought to be ok...though I have no idea what the lower BW limit might be. Any input on this one? Thanks...GTB
