pots
  • pots
    hi,
    does the pots have to be exactly as listed in the parts list.
    like can i use 110k pot instead of a 100k pot ??
    what will happen if i use one a bit bigger, use more power ???
    having big troubles trying to get IC's . i have only found one available to me.
    i have nearly all resisters except the 1nf. can i use 1.4nf in its place?
    any help would be greatly appreciated.
    cheers!
    ahh..thats a 1nf cap..not a resistor.
      That pot should do the job! May give you a wee bit more adjustment!
      If the Capacitor is in the timing lines, I would keep looking. Tolerances on small caps can go that far some cases.
      Jim
        ok..thanks!
