Modification for Speaker
  • Modification for Speaker
    Hi All,
    My first attempt to test my Hammerhead ended up with some smoke coming from the audio pot. That happened when I got with the setting close to the maximum volume. I was using a small power pot, and a 8 ohm speaker. I am not sure I didn't have some errors in circuit, but I think I didn't.
    I put a resistor in series with it (few tens of ohms), to avoid increasing the current through the pot too much. This way it was working ok, but a lot of the audio signal was dissipated by the pot + resistor.
    For this reason, I decided to use an audio transformer to increase the impedance of the speaker. I used a small transformer that I purchased from Jaycar: 1K OHM CENTRE TAPPED - 8 OHM OUTPUT TRANSFORMER
    I still have plenty of sound at maximum volume. Before I had some sort of a harsh sound coming from the speaker at higher volume, now it's better.
    At present, I am using a 1kOhm log pot for the speaker, I will change to the 5kOhm pot when I will get one.
    Nicolae
    hh
    Originally posted by nick_f View Post
    Hi All,
    Nicolae
    hi nick what's your mean to log pot. i think you saying big size of pot. but if you reduce signal from r35 it give you good audio any way i used my nokia mobile audio ear card.
      HI Rajesh,
      Log pot is short for logarithmic potentiometer. The adjustment of volume in audio equipment is done with logarithmic potentiometers, not the linear type. On a potentiometer you can usually find the marking A5kOhm or B5kOhm.
      B means the potentiometer has a linear variation (at half the rotation, you have half the resistance).
      A means the potentiometer has logarithmic variation (at half the rotation, you have about 17% of its total resistance).
      Do some search on the internet about logarithmic potentiometers to find out more.
      Nicolae
        hh
        HI Rajesh,
        Nicolae
        hi nick i seen that good i will replace yet.thank's
