Hi - My PTH version of a RevC HH is nearly complete.
I want to re-align the differential integrator balance now the board is complete and I've made a few changes.
Every DIP IC is socketed, so I was going to:
Have I missed anything - it seems that I can leave IC8 in situ during this, and it would actually be better as any imbalance in the operation of IC8 would also be nulled.
Cheers
- Remove the coil
- Unsocket IC11 & IC12
- Short IC11 Pin 12 to Pin 8 and do same for IC12 - This should turn off Q8 & Q9 & thus turn on both IC7a & IC7b.
- Power up & leave system for 5 minutes to warm up
- Using a 'scope & leaving IC8 in place, adjust R18 for decent voltage on TP4
- Adjust R23 for minimum output on TP5
- Adjust R18 for 0V on TP4
- Check TP5 is still very very small voltage (very low mV)
- Remove shorts on IC11 & IC12 sockets, and replace IC11 & IC12
- Put dab of Locktite on R18 & R23.
Cheers
