I bet it is a temperature effect what you are seeing... VCO drift.
Replies to Minipulse Plus
Originally posted by josewashere View PostQiaozhi. Further investigation into using the TL072 in place of the Ne5532. I hadn't noticed this the other day but if you check at longer sampling delays you will find that the detector ignores metal almost completely. Interesting effect!
Anyone have any ideas why this would be the case?
Originally posted by KingJL View PostGBW (or rather lack of it)!
There are dip adapters, but fairly expensive: http://www.ebay.ca/itm/1PCS-OPA2211A...item3390bb5205
Originally posted by multieagle View PostThere are dip adapters, but fairly expensive: http://www.ebay.ca/itm/1PCS-OPA2211A...item3390bb5205
I made my first PI coil today. Some kind of self supporting basket weave wound free-style with party straws as supports, and hoping for self-shielding action. 300uH sharp. I made it with little more inductance at first and unwound two turns to make it right. Funny, at the end it took 19m of wire, just as the calculation says. One can always cut a 20m wire and expect that a coil will be somewhat over 300uH.
