great to see a ground or power plane on your board. should introduce more repeatability between everyones builds around the world at the very least. S
Replies to Minipulse Plus
Although the Surf-PI and Baracuda are relatively simple designs, it appears that a great number of builders have trouble actually getting them to work.
This seems to be due to either lack of knowledge on how to logically debug a circuit, not checking component values properly and fitting the wrong parts in the wrong places, not having access to the correct equipment for setting up / tuning, or just generally not understanding how a PI works.
The Build Document is an attempt to make construction of the Minipulse Plus easier, and [hopefully] problem free. However, as they say: "Design something that any fool can use; and only a fool will use it". I hope we don't find the same issue here.
Clearly, everyone has to start their learning curve at the bottom and work up, and it's possible that building the MPP will help some people to do that. If so, then I'll be happy.Last edited by Qiaozhi; 06-28-2014, 12:13 PM.
Originally posted by 6666 View PostI have ordered some real J113 fets, in the mean time is there a suitable replacement ?
http://alltransistors.com/mosfet/crs...s=30&caps=TO92
However, I suspect just about any general purpose FET will work, as it's only being used as a switch.
The design is fairly forgiving as regards components tolerances. Although I've specified a 1% tolerance for the resistors, you should be able to use 5% without any issues. As a general rule, I only keep 1% tolerance resistors in stock. Unless you're a pile 'em high, sell 'em cheap sort of person, the odd fraction of a penny in component costs is neither here nor there. For the capacitor voltage ratings - these are also not fixed in stone. As long as the rating is greater than the maximum possible voltage across the component, then it will be ok. For caps on the 5V supplies (for example), simply choose the next higher voltage such as 10V. Of course, that doesn't mean you can't use one rated at 16V (or even 50V). As long as it will physically fit on the board, then it will be ok.
Originally posted by 6666 View PostHi George
I guess a 2n5485 could be used as well.
Originally posted by Dean Sarelius View PostHi George,
I have just purchased the PCB and some other parts from Silverdog the remaining parts from Element14 here in Oz. The one part I could not purchase locally in DIP was the NE5532 so have purchased the MC33078 as a possible alternative..!
