Yes, this seem a 4017 problem. It is not resetting properly. See what happens at pin11 of 4017. Also see if 4017 receives a reset pulse at pin15 or not.
The circuit works as follows... 4017 keeps pin11 high (from the previous cycle) which prevents the oscillator from oscillating. The falling edge of 555 output creates a short reset pulse that puts all 4017 outputs low, and hence enables the oscillator to start oscillation. The first oscillator pulse duration is adjustable relative to the oscillator period, hence GB adjustment. 4017 counts 9 pulses until the pin11 goes high again and stops oscillation. When 555 output goes low everything starts all over.
There is a way to optimise pulse rate in a way that no time is lost after EF pulse until Tx charge starts, and hence improve the SNR of a whole rig. I'll try that.
