Originally posted by green
View Post
Getting ready to build the MPP
Originally posted by baum7154 View PostI would not add windings but instead push the sampling delay toward 6 or 7us instead. There is little to be gained I believe in slowing down your coil further. You have plenty of inductance at 324uh. One question is, have you armored your coil yet? If not, it will probably have the effect of slowing down your coil anyway.Regards,Dan
Originally posted by KRinAZ View PostHmmm, thx Dan, I haven't put a shell around the coil yet - will do that & rig up a pole when I've mostly finished the electronics mods & tuning. I'm curious about how this coil would measure & perform with another basketweave turn, & I am experimenting with a mod to the coil template anyway, so I think I'll make an 8 turn version of the 8x10 & post it's test results...I'll also find the minimum stable & test with that delay & include in the results...may be a couple days...
By an '8 turn version' do you mean that you are going to have 8 wires in each of the slots or about 40 turns on the coil? That should put the coil well in excess of 450uh and I don't think it would decay in under 10us, just guessing. If you take a look at my post #31 in the CHANCE PI COIL thread the attached pictures show an 8" round coil with 39.4 turns of wire yielding a coil with 458uh of inductance. This coil will not allow my CHANCE PI to operate down at even 10us so a larger 8X10 elliptical coil would have even more inductance with the same number of turns.
By the way the increase in inductance after putting a shell or armor on the coil I believe comes from slightly crushing the open coil geometry with the wraps and is almost unavoidable. I have a couple of coils that were used in development of my 3:1 oval or RACETRACK style and after much handling un-armoured, they exhibited an increase of inductance I attribute to crushing. The change was from about 310uh to 325uh or about 5%. I am in the process of armoring with fiberglass a 4" X 12.5" 3:1 'Racetrack coil' and a picture of it ready for fiberglass is in post #232 of the CHANCE PI COIL thread. It now measures 328uh.
Best of luck,
Dan
Originally posted by CAS View PostI tried a coil with a higher inductance and it would not allow me to use a short delay and it didnt make it any better at longer delays (> 30us) although there was no appreciable decrease in performance.
Originally posted by KRinAZ View PostI got a similar result - the minimum delay the coil can be sampled at is now about 12uS, depth in air tests about the same - I'll elaborate a bit in another post...
Originally posted by baum7154 View Post----------------------------------------------By an '8 turn version' do you mean that you are going to have 8 wires in each of the slots or about 40 turns on the coil? That should put the coil well in excess of 450uh and I don't think it would decay in under 10us, just guessing. If you take a look at my post #31 in the CHANCE PI COIL thread the attached pictures show an 8" round coil with 39.4 turns of wire yielding a coil with 458uh of inductance. This coil will not allow my CHANCE PI to operate down at even 10us so a larger 8X10 elliptical coil would have even more inductance with the same number of turns. By the way the increase in inductance after putting a shell or armor on the coil I believe comes from slightly crushing the open coil geometry with the wraps and is almost unavoidable. I have a couple of coils that were used in development of my 3:1 oval or RACETRACK style and after much handling un-armoured, they exhibited an increase of inductance I attribute to crushing. The change was from about 310uh to 325uh or about 5%. I am in the process of armoring with fiberglass a 4" X 12.5" 3:1 'Racetrack coil' and a picture of it ready for fiberglass is in post #232 of the CHANCE PI COIL thread. It now measures 328uh.Best of luck,Dan
Originally posted by Qiaozhi View PostIt depends on what type of target you were using for the depth tests. Sampling earlier allows you to detect targets with very short time constants, such as small gold nuggets or fine jewellry; and you will find a difference in depth for these objects. Unfortunately, sampling earlier also increases ground response.
Threshold on MPP
Thought I'd see what popular opinion is on the Threshold sound for the MPP - personally I have spent many hundreds of hours swinging Whites Goldmasters & Classics & prefer their Threshold sound - never fatigues me & I can distinguish faint tiny targets with it. I have also put in enough time on Garrets, Tesoro's etc. (& they are similar but not the same) to know I like Whites Threshold best. What do others think? Would this be good for the MPP project? or perhaps make a mod to convert MPP to Whites style Threshold for those who want it? Almost all my experience is in the VLF world but I would think it could be the same/similar sound for PI...
I'm not sure what you mean by Whites threshold, so if you are up to it, you may try to demonstrate it in a video?Originally posted by KRinAZ View PostI read thru these posts recently but was unsure of the state of GEB for the MPP - I saw where Davor & others did a lot of great work on, & SilverDollar created nice schematics, do we have a plan & procedure to add GEB now?
Originally posted by KRinAZ View PostThought I'd see what popular opinion is on the Threshold sound for the MPP - personally I have spent many hundreds of hours swinging Whites Goldmasters & Classics & prefer their Threshold sound - never fatigues me & I can distinguish faint tiny targets with it. I have also put in enough time on Garrets, Tesoro's etc. (& they are similar but not the same) to know I like Whites Threshold best. What do others think? Would this be good for the MPP project? or perhaps make a mod to convert MPP to Whites style Threshold for those who want it? Almost all my experience is in the VLF world but I would think it could be the same/similar sound for PI...
Originally posted by Qiaozhi View PostI assume you're referring to a silent-search mode? In other words, it only beeps when a target is found, otherwise there's silence (apart from the occasional chatter).
Originally posted by Davor View PostI'm not sure what you mean by Whites threshold, so if you are up to it, you may try to demonstrate it in a video?My MPP stuck at all components on board, but zero conditions for me to breathe life in it. I intend to make it work with minimum changes, and when I'm happy with it proceed with a GEB circuit. I have it ready, and I have an absolute value circuit ready, but I'm not pushing it yet since I did not test it myself. A GB circuit should work for small gold even without the absolute value circuit though.
Originally posted by KRinAZ View PostSince I'm primarily a prospector searching for gold, I personally usually don't use disc modes if present on a detector - only all metal mode - so I'm actually referring to the Whites threshold sound in all metal mode (Classic series) or just the Goldmaster ("black box" & GMT/GMZ models) threshold (no disc mode so all metal all the time, where the threshold tone is always present (unless threshold control is turned down too low) as a faint hum & gets progressively louder with RX signal strength, but the freq is constant at around 1khz to 1.5khz (I believe, will try to verify) & sounds like a nice sine wave signal, hope that helps & let me know if you'd like more info on it.
