i need help gerber in minipulse plus rev-c project
  • i need help gerber in minipulse plus rev-c project
    can anyone send me a gerber file in jpg format of minipulse plus Rev-C project.
    pls help me
    pls help me
    Please note that the Minipulse Plus PCB layout is double-sided, with plated-through holes and a solid ground plane. Hence it will be extremely difficult to make this PCB at home. I did try to output the top and bottom copper layers to both PDF and PNG (using Gerbv), but the bottom copper layer is not displayed properly; most likely due to the ground plane.
    I would suggest taking advantage of the excellent service provided by Silverdog to Geotech members, and order a high quality PCB from there. They only cost £5.00.
      can i make it through film and print from PCB machine ? it will difficult also ?
      also tell me can silverdog ship PCBs to Pakistan and its shipping charges ?
        Go here -> http://silverdog.co.uk/shop/index.php
        and click on "contact".
          thanks Qiaozhi i discussed with mr.andy and order 3 boards
