I have worked with boards with soldering on one side only. These boards where solder flows through to seal with the top are a real challenge, for me, to desolder a mistake, or failed part. Any suggestions on how best to desolder and replace a part on the MPP pcb?
Two-sided boards - Desoldering
Originally posted by multieagle View PostI have worked with boards with soldering on one side only. These boards where solder flows through to seal with the top are a real challenge, for me, to desolder a mistake, or failed part. Any suggestions on how best to desolder and replace a part on the MPP pcb?
Alternatively, you can simply cut off the pins (as before) and solder the replacement onto the wires that are left.
Using a solder sucker and iron is a bit of an art. You also need an iron that holds its temperature well.
Soldering iron flat to the PCB on one side of the pin sucker on the other. Also don't let the sucker pull away when the plunger is released. Practice on a old board. The solder will not flow properly unless some fresh flux is added.
Some boards are harder to desolder due to smaller holes. The excellent Silverdog board are quite difficult for this reason.
Solder wick come in different quality. Bought some from DX.com that had good reviews it's nowhere near as effective as some loctite solder wick I had here
Once upon a time I worked in a shop in Miami where every station had two irons, one of which equipped with desoldering hollow bit and a good vacuum pump. It works perfectly for through hole. I've not seen such arrangements gain popularity though.
My weapon of choice is a desoldering braid.
Originally posted by Davor View PostOnce upon a time I worked in a shop in Miami where every station had two irons, one of which equipped with desoldering hollow bit and a good vacuum pump. It works perfectly for through hole. I've not seen such arrangements gain popularity though.
