Hi All,
I am using Minipulse Plus Rev-D for my project at uni to detect buried manhole covers. I have been following the instructions document closely to instruct and check the PI circuit. There is one small issue though:
All I am getting on TP9 is fluctuating noise http://tinypic.com/r/sc52so/8 (photo attached), and that voltage doesn't seem to change whenever metal is present.
I went through the documents twice double checking all the voltage readings as suggested in the document and everything else is fine.
Thank you all.
Useful info:
Coil inductance is 380uH
Coil is connected to the circuit through two wires (photo attached)
Output Frequency at is 1kHZ
"If you have an oscilloscope, then monitor the signal across the damping resistor using a x10 probe,
where you should see a flyback signal of about 350V." I am getting a fluctuating voltage for this, varies from 500mV to 4V.
Thank you all.
Useful info:
