I have some questions on the specifications and rating of components. I am trying to figure out pricing and such and having some frustrations.
1) temp rating: is lowest OK or should I choose one that is -20c to 120c (approximatly)
2) capacitor rating, form and material I am assuming polyproplene/polyester material since none is given.
3) strange numbers 2n2, 470r, 3r3 I assume 2200F, 470Ω and 3300Ω
4) from factor of IC's pdip? I want to use through board and chip sockets
5) diodes 500mW High Speed Switching Diode (general purpose)?
6) a) Reject (sample delay) pot 100k LIN
b) Audio (threshold) pot 250k LIN
c) R06 resistor 100k multiturn preset
7) any other things I may not know about?
original component list
Resistors (1% 250mW, unless stated otherwise)
R3 3R3 2W
R2 10R
R14,R15 27R
R28,R37 100R
R18 220R
R1 470R 2W (damping resistor)*
R38,R39 680R
R12,R16,R30,R32,R33 1k
R7 1k2
R24,R25 2k2
R36 4k7
R20,R23 6k8
R4,R9,R10,R19,R21,R26,R27,R35 10k
R5 20k
R11 22k
R8,R31 27k
R13,R17 33k
R34 47k
R22 56k
R6 100k multiturn preset
R29 1M
* Actual value is dependent on coil
Capacitors
C20 100pF
C8 220pF
C11 2n2
C10 10nF
C6,C16 47nF
C21,C22 100nF
C12,C13,C14,C15,C17 470nF
C18 1uF
C3 10uF 10V
C2,C4 22uF 10V
C7,C9 47uF 10V
C5,C19 100uF 10V
C1 1000uF 16V
Diodes
D1D9
1N4148
D10 MUR460
Building the Minipulse Plus (REV-D) - [Doc. Ref. 20150712] 9
Transistors
Q2,Q6 2N3904
Q5 2N3906
Q1 IRF740
Q3,Q4 J113
Integrated Circuits
U3 78L05
U1 79L05
U2 LT1054
U6,U7 MC14538BCP
U4,U10 NE555
U5 NE5532
U9 TL061 (or TL071)
U8 TL062 (or TL072)
Miscellaneous
Battery pack 8x AA batteries (12V nominal)
Search coil 300uH to 500uH (TX)
Speaker 8ohm to 64ohm
OnOff
switch
R3 3R3 2W
R2 10R
R14,R15 27R
R28,R37 100R
R18 220R
R38,R39 680R
R7 1k2
R24,R25 2k2
R36 4k7
R20,R23 6k8
R5 20k
R11 22k
R8,R31 27k
R13,R17 33k
R34 47k
R22 56k
R29 1M
Capacitors
C20 100pF
C8 220pF
C11 2n2
C10 10nF
C6,C16 47nF
C21,C22 100nF
C18 1uF
C3 10uF 10V
C2,C4 22uF 10V
C7,C9 47uF 10V
C5,C19 100uF 10V
C1 1000uF 16V
Diodes
D1D9
1N4148
D10 MUR460
Transistors
Q2,Q6 2N3904
Q5 2N3906
Q1 IRF740
Q3,Q4 J113
Integrated Circuits
U3 78L05
U1 79L05
U2 LT1054
U6,U7 MC14538BCP
U4,U10 NE555
U5 NE5532
U9 TL061 (or TL071)
U8 TL062 (or TL072)
Miscellaneous
OnOff
switch
