Originally posted by Tibuck19
View Post
MPP Beach REV-E
Hi all,,,Thanks again for all the help, I really appreciate it,,,,Before I decided to swap out the IC's I took both Detectors out into Farm lands near my home. There are not many houses on the street where I live and the street is totally surrounded on all sides with miles of Farm land. I took both Detectors out into the fields, miles away from any power lines, houses etc, and both detectors sound exactly the same as I tested them at home. I then swapped out all the IC's and there was no change. The IC's are from reputable companies. Apart from how it's sounding I'm really happy with the depth and sensitivity. @KT315,,,thanks for the information you quoted by Eric Foster. Would some one be able to tell me how to measure the frequency of the 555 that creates the main pulse please?,,,I have an oscilloscope but I'm not sure where to place the probes. I'm still learning,,and it's great to have help from such knowledgable people here on Geotech. Thanks again. Marty
Originally posted by waltr View PostThere are lots and lots of threads in the 'COIL' sub-forum about shielding and making Fast coils.
Do read and remember that shielding CAN increase the Capacitance and SLOW the coil's decay severely.
Originally posted by MartyJ1963 View PostHi all,,,Thanks again for all the help, I really appreciate it,,,,Before I decided to swap out the IC's I took both Detectors out into Farm lands near my home. There are not many houses on the street where I live and the street is totally surrounded on all sides with miles of Farm land. I took both Detectors out into the fields, miles away from any power lines, houses etc, and both detectors sound exactly the same as I tested them at home. I then swapped out all the IC's and there was no change. The IC's are from reputable companies. Apart from how it's sounding I'm really happy with the depth and sensitivity. @KT315,,,thanks for the information you quoted by Eric Foster. Would some one be able to tell me how to measure the frequency of the 555 that creates the main pulse please?,,,I have an oscilloscope but I'm not sure where to place the probes. I'm still learning,,and it's great to have help from such knowledgable people here on Geotech. Thanks again. Marty
Originally posted by Qiaozhi View PostI wouldn't get too excited about the release of MPP Gold. At the moment it's just an idea that's still in the "getting ready to get ready" stage.
The first 555 is the Pulse Rate for the TX and ALL following timing. Scope of TX's MOSFET drive will show the Frequency.
Do this with both detectors and I'm sure you will find that they are NOT running at the same frequency- this is NOT due to bad chips but simply the result the component tolerances. Remeber that the frequency of a 555 is set with Resistors and capacitors. So a slight trimming the the 555's freq setting R will tweak the frequency.
Thanks Waltr,,,,,Can't understand why the Rev E detector still gives a scratchy ticking sound out in the middle of nowhere,,it sounds exactly the same in my projects room,,no change???,,How do I test the frequency of the 555 that creates the 'Ticking' sound,,IE: Where do I place the oscilloscope probes? Grateful for the help Waltr. Thanks. Marty
Only thing I can suggest is use the scope and compare Stage by stage on each detector to find where the signals are different.
Did you use same quality/tolerance caps & resistors?
Thanks guys,,,,,When I first built the Rev D MPP I had a few mishaps because I had to resolder in a couple of places which caused some of the solder pads to lift - Silverdog (Andy) kindly offered to take a look for me and he repaired it for me,,,he did a great job with it and it works perfectly. I strictly took my time over 3-4 days building Rev E MPP and actually wrote every component down in my notes before soldering them in place,,,all resistors were 1% and every component was double checked with 2 different multimeters (In case of different readings) and then,as I've said, I logged it in my notebook before soldering. I have rechecked every stage also. Where do place the scope probe to check the 555 frequency? Apart from doing that next, I have swapped out all the IC's, several times, and there's no change, I know all the IC's are OK because I tried them in all my other builds that use those IC's and they're fine. I've ordered several more 220k Pots to try because sometimes as I'm turning the pot towards the point of a low growl, it begins to crackle and become high pitched and scratchy. Maybe a faulty Audio pot?,, Thanks again guys.
Marty ... I can assure you that the audio on the REV-D and REV-E versions should sound exactly the same. Your problem has nothing to do with anything beating with the mains frequency. In fact, your test in the field proves that.
Also, there's been some talk in the replies concerning the TX pulse rate, and whether you should use a higher pulse rate. This also has nothing to do with this particular problem.
Is it possible that you do not have the Threshold pot connected correctly? Without this pot connected, you would get exactly the results you describe. i.e. a high pitched audio tone with a scratchy note, but also some target detection.
Hiya Qiaozhi,,,,,I've finally solved the problem,,,and I feel so silly!,,At first, I thought it may be one of the IC's,,but after swapping them all out, numerous times, I found it was a faulty Audio pot all along!,,Both the Rev D and Rev E do now sound the same. Also,,and I'm honestly not exaggering, and I've tested it both in the Farm land and in my project room, I'm getting 14" on a 1 Euro and 12" on an English 5p piece,,,,is this good?(normal?),,,I'm really pleased with this detector and will be ordering another board soon for my partner Claire. The sound is really clear and sharp now. Could you tell me what the Threshold and Gain pots do and how to use them? Sorry for the foolish question but the depth tests I did were with the Gain and Threshold fully off. I want to thank you all so much for your knowledge and help and hopefully, when my new camera arrives (and I've learnt how to use it,,lol), I'll try and put some clips together before and after I seal it all up,,,can't wait to finish the shaft and enclosure now,,,I've carved some handles from some Yew wood that I cut and season myself that I use for making Longbows and hunting bows. Thanks again all. Marty
