My recently completed MPP seems to be working well as far as sensitivity, but ‘sounds’ with fast swings or sudden direction changes such as at the end of swings. It makes no noticeable difference if I swing the coil close to the ground or higher in the air.
I suspect that this is due to sensitivity to the Earth’s magnetic field and have read all I can find on the Geotech website and in IMTD and have also thoroughly rechecked the circuit board components, especially around the sampling integrator.
It responds to a small ceramic magnet at about 5” from the coil but only weakly to a 1/2” ferrite toroid.
The sample pulse generator section seems to be producing the correct pulses when viewed on the CRO.
I am using an 8” 3DSS with a bit of extra graphite shielding and a twisted pair feedline. I have tried another bundle wound coil with similar results.
The control board is shielded above and below in a copper clad pcb board sandwich connected to B+ (0V).
As it is, it is useable but the falsing is annoying so any suggestions on what to check and what measurements to make would be appreciated.
