HiYa all,
Just had an idea about using the MiniPulse RevE circuit, and adding another op-amp pre-amp stage, together with a double overlapping coil + FET driver, so that it would do automatic ground balance as in the attached document.
Seems like Minipulse has a better front end than the old document circuit so might go quite well ..
What do you all think?/
I am all for keeping it simple, so if the addition of a preamp and a different coil + driver, can do away with a complicated ground balance circuit, uP based or otherwise, then I am all for it.
Seems like getting rid of the ground effect the closest to the source would be the answer to me ..
My 2c
My 2c
