replacement MC14538BCP with CD14538B possible?
  • replacement MC14538BCP with CD14538B possible?
    U7-u8 MC14538 can i replace it with CD14538B?
    thank you!
    Devis from Italy
    thank you!
    Devis from Italy
    Hello Devis,
    Yes you can use the CD14538B. I use them on my Mini Pulse.
    I did a series of videos for the Mini Pulse Plus that might be of interest to you here is a link:
    https://www.youtube.com/playlist?lis...x32pI5m-di2GTf
      if you buy from chinese there are not motorola or texas instruments, because US.
      so no difference. chineses can mark like they want, under any label.
      also they sell chips without signs, clear. anyway, just you must check ICs they are working or not.
        What brand of box did you use to insert your minipulse ?
          I used a Pelican brand box for my Mini Pulse Plus.
            https://m.youtube.com/watch?v=MLF-XI77D-c
            I have finished my minipulse
            The result is truly amazing
            I built a very fast coil
              Hello Devis,
              Nice job on your Mini Pulse. What are the specifications of your fast coil?
                Hello Devis,
                I used a cable for tv / SAT wiring I removed the shield
                20 turns,238mH, 2.5 ohm, dumpin resistor 940ohm (470 ohm +470 ohm series)internal diameter coil 245mm
                I used duct tape for automotive applications
                and applied graphite shielding
                without shielding the signal decays in about 8 micro seconds,with shielding I have yet to check
