Wanted "ADMIRAL"
  • bc327 bc337 in admiral, bc327 bc 547 in this diagram, is it working?
    • displaced
      • Thank you Emerson for sharing this files
        • Thanks for sharing Emersonpaz, have the devices in these files been tested and I need the wire information for the coil
          • Originally posted by bonchev2 View Post
            Hello colleagues, maybe my question is a bit stupid but I want to ask what is the difference between MC1458 and LM358 because I replaced it and the result is the same. The bipolar power supply works perfectly with the LM358. thanks in advance
            1458 has short-circuit protection.
            • Thanks for the reply.
              • lm324 13 pin 14 pin 47 k direnc y?kseltin 200k ?ift ton stabil olacak sivic ucdan uca direnc takın 4m7
                • lm324 13 14 pin 47 k 200 k insert 2 ton switch end to end 1 and 3 pin 4m7 resistor 2 ton will be fixed
                  • Thanks for share this info. Put video in Youtube to see how is works on field. Greetings!!!
                    • I'm going to shoot a new video soon. There is a wrong resistor on the pc and the schematic. The pcb has changed from beginning to end. When you open it too much, the caploya makes a noise because the resistors do not meet the voltage.
                      • [3/1 01:01] Cebrail: https://youtu.be/qyNBzTctH7Q
                        [3/1 01:02] Cebrail: https://youtu.be/hJ6OZvF4xFY
                        • After several experiments with different components and their replacement...
                          https://www.youtube.com/watch?v=TBFeRk4ZdKY
                          I think it turned out well...
                          • Comment
                            • Hello friends, I want to get the two-tone Admiral PCB file and the location of the variable resistors
                              The second question is, is the two-tone board separated from the main board? I would like a response from you, and thank you very much
                              • Peace be upon you, where is the location of the toggle switch between the two tones on the board?
