Wanted "ADMIRAL"
  • Originally posted by getsa View Post
    Hi Cebrail,
    What do you mean by adjusting the resonance?
    The transmitter is autogenerator - switching the power it started generate sine wave, and if the value of the capacitor changes, it only affects the frequency.
    ​​The receiver is an amplifier implemented according to a common base circuit and is a non-resonant circuit. Is it a matter of selecting the capacitor, that is in parallel of the 15k in the emitter of the transistor?
    Greetings.
    tx 23 vpp bc337 connected 33 k bc 327 connected resistor ohm ground opamp LM 393 2 pin 1pin 7 pin and rx serial parallel capacitor tl072 connected resistors
    • What is the value of resistance, with all due respect and appreciation?
      • I use 68 ohm but can be use trimpot for fine tuning of oscillator current
        • Thank you. I will assemble the painting within the next week. Thank you from the State of Jordan
          • Originally posted by bonchev2 View Post
            What is the actual size of board?
            • Originally posted by Sarkim View Post
              ~ 84x87 cm.
              • Mine is 83x83 mm. but now I made smd version with is 99x78 mm with potentiometers on it for more stable work but is not tested yet. I will posted when is done.
                • Originally posted by Toros View Post
                  ~ 84x87 cm.
                  Thanks brother
                  I see your reply to me, apologies I was busy didn't check notification
                  • Comment
                    • Well done!
                      It will be interesting to share your impressions after testing that version outdoors, on a real terrain, compared to the DIP version.
                      Cheers!
                      • Comment
                        • SMD is more stable. I like it. I have Ideas to change a search coils data a bit. Greetings!!!
                          • Congratulations on another success!
                            Suounds curious, regarding the coil optimization...?
                            Interest remains high - keep going!
                            Greetings!
                            • Admiral Quasarhttps://youtu.be/qd9Am9hMmeQ?si=jScmYNJGBA4t6PE4
                              • Originally posted by CEBRAIL View Post
