Wanted "ADMIRAL"
  • #76
    PCB top and bottom
    • #77
      Guys, I'm sorry, I missed one track. Who has already assembled the device on this board?Click image for larger version
      • #78
        • #79
          • #80
            Replaced the denominations (the threshold tone became even, without disruption)Click image for larger version
            • #81
              y. x olan yere ne takılacak ben ayrımı yakalayamıyorum tx 1.050 mh 330 n rx 7.50 mh 47 n
              • #82
                X and Y points, LCD indicator is connected
                • #83
                  metal ayrım yapmıyor bu konuda yardım edermisiniz
                  • #84
                    • #85
                      turn the "discrimination" potentiometer until the ferrous metal is removed
                      • #86
                        32 DD tx 1 mh Rx 7.50 mh demiri silmiyor rx 080 mili volt tx 7.50 milivolt
                        • #87
                          How much is the variable resistance value beside the 470uf capacitor
                          Thanke you.
                          • #88
                            How much is the variable resistance value beside the 470uf capacitor.
                            Thank you
                            • #89
                              This is a multi-turn trimmer resistor (100-200 ohm) for setting the voltage of the transmitting coil, an undistorted sine wave of 16-18 volts is set
                              • #90
                                Thank you very much again.
