Wanted "ADMIRAL"
  • Potentio meter be installed and adjusted instead of r45 39 k
    • Checking the tressh stability behaviour outside and air test.
      https://www.youtube.com/watch?v=I4M8Ds8hE78
      • ... and here's how my latest PCB works - outside the workshop:
        https://www.youtube.com/watch?v=ob1nYn2LGC8
        Everithing is still very "raw", but for now I'm happy with the result...
        Cheers!
        • hi all,
          RX and TX with aluminum foil shielding
          • Hi gurdal, very nice work can you shared TX & RX data and what wire you used. Greetings and all the best
            • Originally posted by bonchev2 View Post
              Hi
              TX 1.114 Mh-0.30 330NF
              RX 7.15 Mh- 0.60 68NF
              • Thanks gurdal
                • Which one is better guys, aluminum foil shielded coils or graphite?
                    I use graphite
                    • I tested both, not much different, I suspect that bad shield is causing more ground influence, so I make coil inside copper tubing = 100% shield.
                      testing results = The influence of the soil is the same for all 3 of them​.
                      coil inside copper tubing.
                      Click image for larger version  Name:	cu rx.jpg Views:	0 Size:	23.6 KB ID:	420601
                      to check quality of shielding spray some water on finished coil, no signal changes = good shielding
                      • Originally posted by gurdal View Post
                        Hi
                        This is Admiral1 VLF Metal Detector.
                        Coil is TX 0,4mm 1mH 330nf, RX 0,25mm 12mH 22nf
                        Calculated Frequency of 8,7kHz. Null voltage 9mV possible lower with more sens
                        • Originally posted by Toros View Post
                          RX 22nf ? Strange, what must be frequency of receiver?
                          • My coils are not affected by graphite coated soil. If the resonance is adjusted well, it goes deep very well. I removed the copper belt lock from a depth of 50 cm. The size is about 3cm
                            • Originally posted by CEBRAIL View Post
                              Make video I like to see it. Thanks
                                Hi Cebrail,
                                What do you mean by adjusting the resonance?
                                The transmitter is autogenerator - switching the power it started generate sine wave, and if the value of the capacitor changes, it only affects the frequency.
                                ​​​​​​​​​The receiver is an amplifier implemented according to a common base circuit and is a non-resonant circuit. Is it a matter of selecting the capacitor, that is in parallel of the 15k in the emitter of the transistor?
                                Greetings.
