Hi all,
the latest cross section of a thick straight wire of short length indicates, that the amperes law doesn't work well at the endings and beyond of the wire. This effect is called the "edge effect".
One can clearly see the discontinuity of the magnetic field density at the wire endings. But the f|_|cking publications and text books doesn't say it explicity, that the amperes law doesn't work for finite lenght straight wires. I haven't found anything, that would help me.
The solution is simple but it costs more calculation time. I have to divide the entire wire element into more finer wires with lower diameter (thick wire model -> thin wire model). At the end, I can really model the frequency dependent inductance, frequency dependent resistance (and time constant), rectangular cross section wires, tube wires, thin foils, etc.
The target coil model can be modelled as a thick disc coil with rectangular cross section. I would only need one target model.
Unfortunately, the coil software must be redesigned at some certain parts. But I can answer some of my open questions and thesis.
Cheers,
Cheers,
